Installed rear sway bar-Thoughts
  • 1 Post By Ray_Dockrey
Old 16 Mar 2013, 06:07 pm
Ray_Dockrey's Avatar
Default Installed rear sway bar-Thoughts
Got my rear bar installed this afternoon. I found some 3/8" speed nuts at Autozone and they worked perfectly. We also found if you bend up the lip on the axle where the slot is it will allow the bushing bracket to swing up easier and the bolt will start easily.
We also didn't take the rear wheels off. We were able to put the bolt through the swaybar end link and then swing it up and start the bolt. Then used a ratcheting wrench to tighten them on up.
Hope this helps somebody. Also to add, I got the swaybar and all hardware at the junkyard for $25.
rcktpwrd likes this.
Old 20 Mar 2013, 05:53 am
Default Re: Installed rear sway bar-Thoughts
How much does it affect the way the car drive on the PT?
Old 20 Mar 2013, 06:30 am
A pretty big difference. I was pretty surprised just how much a difference it made.
Old 21 Mar 2013, 06:11 pm
Interesting. I'll have to look into it once I pick out wheels and tires.
Rear sway bar kit turbomangt Turbo Wheels/Suspension/Handling 10 05 Jul 2005 12:40 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Coilovers and sway bars installed Hardsuit Turbo Wheels/Suspension/Handling 3 02 May 2004 01:54 am
Installed OEM Rear Sway Bar silky Turbo Wheels/Suspension/Handling 20 22 Mar 2004 05:00 pm
sway bar installed by dealer LAF Turbo Performance 5 08 Sep 2003 05:42 pm
