Rear rattling/ clunking
Old 21 Mar 2013, 03:37 pm
Default Rear rattling/ clunking
I have a lot of clunking, more like rattling coming from the rear of my 07 touring edition. I did some searching and a lot of reading here on the forums and thought I found my answer. I replaced the bellcrank and not the upper and lower watts links. They appeared to be in good condition and not at all loose or warn and in more than a few responses to other posters questions, the consensus was to not replace them unless it was obvious that they needed it. To be completely thorough here with my info, the bellcrank also did not appear loose or warn and did not clunk or move when I rocked the car from side to side. I decided to replace it anyway because again the consensus was that a bad bellcrank wont always reveal itself upon inspection. The rear shocks are new, only a few thousand miles old. I did not replace the springs because they didnt appear to be sagging. Also all the nuts and bolts that I can see and put my hands on seem to be in good shape and tight. At this point my brain tells me it should be pretty obvious that the upper and lower watts links need to be replaced but that is why I am here asking first. I have learned my lesson more than a few times in the past NOT to throw money at what seems to be the obvious problem because in my experience only about 1% of the time it actually is... ANY suggestions would be greatly appreciated.
Old 22 Mar 2013, 12:21 am
Default Re: Rear rattling/ clunking
Jack/handle, spare tire, shock bolts.
Old 26 Mar 2013, 05:56 am
Be sure the spare is tight.
Also check that you haven't lost an exhaust hanger - the exhaust can hit the axle if a hanger or 2 goes.
Old 26 Mar 2013, 06:09 am
jrbsr05pt's Avatar
Dang it!!!! You beat me to it. It's your exhaust most likely op.
2005 n/a 5 speed. 177365 miles. spectre cold air intake, white and pink leds under dash and back seats, purple leds in vents, wall with 1 18" subwoofer built behind back seat(soon to be either 16 American bass vfl8's or 4 18's with the wall rebuilt all the way to behind the front seats,cant wait!!!), blue dash lights, pink turn signal indicators. 3D tails and tinted backup lights. Power antenna (that no longer has power ha!) another one gone but wont be forgotten
2003 gt turbo. 130245 miles. autostick, mopar riceplate, 3" o2 housing and downpipe. custom diablo tune (totaled, gone but not forgotten)
2003 dream cruiser. autostick, mopar body kit, mopar bov, cai. s1 injectors. mopar s1 pcm. 3" 02 housing and downpipe installed from last turbo, upper IC hardpipe more on its way soon.......... diablo tuner in the near future.
Rear rattling/ clunking Jayson_Dread Turbo Wheels/Suspension/Handling 13 22 Mar 2013 01:18 pm
Rattling noice from rear wheel ? tomkruhlmann General PT Cruiser Discussions 0 13 May 2008 03:45 am
Rear end rattling Rymanrph Sound and Security Forum 11 13 Jan 2006 01:43 pm
Rattling rear! xyster Sound and Security Forum 5 15 Sep 2005 11:57 pm
Rattling Clanky Sound In Rear Of Car ptcruzin42 Tech & Performance Forum 21 08 Feb 2003 04:09 pm
