Ball joint replacement
Old 11 Apr 2013, 09:12 am
Tobymelodeon's Avatar
Default Ball joint replacement
Hi,
Just found my PT has a split gaiter on the ball joint. This is now an MOT fail here in the UK so need to change the joint. Anyone ever done one? I've got a new joint (no time to get a complete wishbone here) but just wondered if anyone had any tips on removing the old one without a press. Any help and advice greatly accepted! Already replaced all bushings with Energy ones so kinda know my way round the front suspension etc.
Old 11 Apr 2013, 01:18 pm
Default Re: Ball joint replacement
What a job!!! Finally finished but ended up just replacing the gaiter as the ball joint looks good. Now have spare ball joint if I need it but will need to use a press to get old one out! I hate working on the driveway in the rain. Gonna have to butter up my father in law as he owns a huge workshop including pit!
Old 22 Apr 2013, 12:21 am
Be glad your in the UK haha
I have to work on my PT in 4ft of snow some days :-p
Ball joints are easy to remove.
Take off the control arm. Turn it upside down, take a chisel, stick it under the joint, then take a 5lb hammer and smack it 4-5 times. it will fall off.
Must be pressed back on however :-D
Front Ball joint replacement Easy or Hard?? ab1 Wheels, Tires, Suspension 9 10 Sep 2012 01:15 pm
Ball joint dust boots? chuck2112 Tech & Performance Forum 2 06 Feb 2010 09:17 pm
Help with Ball Joint Mrz Wheels, Tires, Suspension 3 30 Mar 2009 06:57 pm
Ball Joint Replacement: Still having problems CarMah Wheels, Tires, Suspension 2 11 Jun 2008 09:07 pm
Bad ball joint replacement? Samson Wheels, Tires, Suspension 4 19 May 2008 05:40 pm
