Quick question about lug studs
Old 12 Apr 2013, 03:36 pm
Default Quick question about lug studs
So, I ended up getting a flat tire yesterday. No big deal I thought. 14 hours later i finally get the tire off. Turns out the lug stud had stripped at the base, the splines were all worn smooth. had to drill it, dremel it, hammer it, and break it out in pieces. Anyways, the question I have is this. On the the hub, are there notches where the splines are supposed to fit, or is the edge of the hole you put the stud through smooth. I've already had to replace a few studs on the front last summer, but can't remember.
It's a 2001 limited edition.
Thanks guys.
Old 12 Apr 2013, 08:16 pm
Default Re: Quick question about lug studs
Smooth if I remember. Not important though. They either over tightened with a air wrench or they been run with wheel loose. You should not be having these issues.
quick question Bonecruiser General PT Cruiser Discussions 10 20 Nov 2012 01:11 pm
quick question choprdoc General PT Cruiser Discussions 2 20 Oct 2012 08:06 pm
Quick Question Busa_Powered General Turbo Discussions 1 31 Jul 2012 10:18 am
Quick question IamN00bz General PT Cruiser Discussions 4 25 Mar 2012 11:06 pm
Quick question for help :/ niel Tech & Performance Forum 8 02 Oct 2011 01:12 am
