Front Sway Bar Diameter
Old 20 Apr 2013, 11:00 pm
Default Front Sway Bar Diameter
Can anyone tell me what the stock diameter is for the front swaybar on a 2002 PT Touring Edition? I'm planning on getting new endlinks and would like to do the bushings at the same time. O'Reilly's lists two different diameters available 24mm and 26mm.
The ground here is too wet to get underneath and measure the bar diameter. I just thought some one would happen to know.
Thanks,
Steve
Old 21 Apr 2013, 08:03 am
Default Re: Front Sway Bar Diameter
It's been asked before.......
Front sway bar size (diameter)?
Old 21 Apr 2013, 10:39 am
Thanks, Carey. I must've missed that post.
Old 21 Apr 2013, 03:55 pm
I've been told that the convertibles are at 26mm... guess I'll find where my measurer is and go measure...lol
Edit - okay, just measured mine, '06 GT vert, mine is 26mm.
Old 21 Apr 2013, 05:32 pm
My 05 GT front is 25.98mm measured in 4 places, so I guess we will say 26mm.
Old 26 Apr 2013, 10:01 pm
Just got my PT back from the shop. I had the front lower torque strut replaced as well as the two center swaybar to frame bushings and the Watts link replaced. Holy crap...what a difference in how the car rides/sounds. It used to sound like I had a wooden box of rocks strapped to the front end when I went over bumps or train tracks. All of that is gone now!!!
When I ordered my Watts link, I ordered a Watts link bushing kit from Energy Suspension thinking it was also needed, which contained two large rubber bushings as well as two tubular metal inserts. My garage said that they didn't need them, and didn't even know where they go. Can anyone tell me if these are needed? Are they for the outboard end of the suspension pieces that connect to the Watts link? I haven't had a chance to lay underneath the vehicle and have a look yet.
Old 26 Apr 2013, 10:07 pm
Uh yeah....those would be bushings that connect the wattslink to the stabilizer bars..........i think you need to go back to the mechanic and tell him to install it correctly......
Sounds like he shoved the wattslink onto the old hardware :/
Old 27 Apr 2013, 12:59 am
Old 28 Apr 2013, 12:46 pm
NitroPT,
In looking at the picture that you posted, I've got a couple of questions. First, it appears that these bushings go over the threaded stud coming out of the ball end of each of the Watts links, between them and the Bellcrank, correct? What about the metal sleeves that I got with the Energy Suspension bushing kit? Do they go over these threaded studs as they pass thru the Bellcrank? I looked at the PT Repair manual that I downloaded from this website as well as the 2002 parts manual, and neither actually clearly shows (or identifies) these bushings, or the metal sleeves for that matter.
If you could clarify these points for me, I'd really appreciate it. Then I can go back to the guy that did the work on my PT and explain it to him.
Thanks, Steve
Front sway bar size (diameter)? scrisp2 Wheels, Tires, Suspension 7 24 Jun 2012 08:31 pm
wtb Front Sway Bar rojna Classifieds: Want To Buy 4 26 Oct 2011 10:16 pm
Non Turbo PT front Sway bar onewickedkid05 Classifieds: Want To Buy 0 17 Jun 2009 05:19 pm
End Links front Sway Bar PTGT Redman Turbo Wheels/Suspension/Handling 9 29 Oct 2003 11:59 pm
Anyone look at their FRONT sway bar?? nbr10 General Turbo Discussions 3 06 Jul 2003 02:46 pm
