Lower control arms So much fun
Old 12 May 2013, 08:50 pm
Default Lower control arms So much fun
Okay I have a 2004 Pt touring with 145000 miles on it. It was over do for the lower control arms, struts, and the fan. So I made a day out of it. Everything went very well except the driverside vertical control arm bolt. It came out easy enough but in the process I lost the nut. I know they are suppose to be semi captive and I had to have it rewelded into place with the last set of a-arms. The bolt is very chewed up and I need a nut.
Does any one have the part numbers for the bolt and the nut so that I can be prepaired when I go to the dealership tomorrow.
Also I snapped three of the four sway bar bolts so I will have to drill them out. Any types of drill bits or easy outs you all use???
Old 12 May 2013, 11:01 pm
UptownSport's Avatar
Default Re: Lower control arms So much fun
You need the nut inside the frame rail?
Go to link in my signature and DL the correct parts manual.
I'd just use a center punch and go progressively larger bits.
I'd use formagasket #3 if you're having that much trouble with corrosion.
Lower Control Arms 450HP Wheels, Tires, Suspension 4 19 Jul 2012 05:54 pm
Lower control arms raymont Tech & Performance Forum 3 02 Jan 2012 10:03 am
Lower control arms LNBNDN Wheels, Tires, Suspension 2 08 Jul 2011 07:13 am
lower control arms. AlexJB Classifieds: For Sale/Trade 2 01 Dec 2008 05:25 pm
Lower Control Arms delrosen Tech & Performance Forum 3 10 May 2008 04:43 pm
