replacing front lug bolts with caliper on
Old 17 May 2013, 03:03 pm
Default replacing front lug bolts with caliper on
I have a broken bolt and research indicates to remove the caliper and rotor, then align notch, then beat stud out. Can I do this without removing caliper and rotor/
Old 17 May 2013, 03:28 pm
cruserdad1976's Avatar
Default Re: replacing front lug bolts with caliper on
I think you can the rotor just sitts on the studs anyway and the calpier holds the pads so id say as long as you can get that slot to line up the big thing here is to NOT mushroom the stud beating it out
Old 17 May 2013, 03:30 pm
What is the best way to beat it out without mushrooming it?
Old 17 May 2013, 03:41 pm
something like a center punch and a good heavy hammer set that punch in the middle and give it a few solid hard wacks it should slid back
Old 17 May 2013, 03:42 pm
one more thing IF the stud is not brok all the way off and if you can get a lug nut on it some time you can hit the lug nut and pop it loose but this will probally mess up the lug
What Torque For Caliper Mounting Bolts? bob2006 General PT Cruiser Discussions 14 19 Jul 2012 08:28 pm
Changing front brake caliper right now - NEED HELP. PTBluiser Tech & Performance Forum 4 13 Nov 2011 04:55 pm
WTB: Front caliper brackets xwing777 Classifieds: Want To Buy 4 04 Oct 2011 10:35 pm
Need to replace front brake caliper tubularbel General PT Cruiser Discussions 7 20 Sep 2011 02:06 pm
Cable from front of Brake Caliper Coop Tech & Performance Forum 17 14 Oct 2010 09:05 am
