Tire/wheel question
Old 18 May 2013, 04:12 pm
Default Tire/wheel question
Have an 03 and am thinking about going to steel wheels but I have a question.
I want to fill the wheel well as good as I can without lowering. Since I'm going to purchase the wheels I can go with 15 or 16" wheels.
My question is: Should I go with the 15" and taller tires, or stick with the 16's and get as tall a sidewall as can fit.
2008 Sunset Boulevard
Old 18 May 2013, 04:50 pm
Default Re: Tire/wheel question
It's the same either way. Just depends on you tastes far as the tire to wheel ratio. Also so your speedo will be off big time.
Old 18 May 2013, 05:30 pm
Busted; thanks for the info. I currently have 16's on it so would I be better off dropping to the 15 with taller tires. The rims are aftermarket and with standard tires I only have about 1/4 inch between the tire and the bottom of the strut spring.
Not so concerned about speedo cause I always drive with a gps and can see the speed on it.
Old 19 May 2013, 05:03 am
Teska's Avatar
But you do realize that this way your car will even get higher, your suspension will not be as firm anymore and your car will have worse roadability ?
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Spare Tire/Wheel Question PTJunkie Wheels, Tires, Suspension 13 16 Feb 2013 09:49 pm
Different TPMS question - new tire/wheel set BigDodgeGuy Wheels, Tires, Suspension 2 28 Dec 2012 02:47 pm
Newbie with Wheel/Tire Size Question digitalpinscruiser Wheels, Tires, Suspension 6 27 Jun 2008 06:04 am
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
Tire /Wheel Question GTPT General Turbo Discussions 10 23 Sep 2003 02:00 am
