I'm Back!. With photos of course :-D
Like Tree2Likes
Old 24 May 2013, 12:20 am
Default I'm Back!. With photos of course :-D
I have not been on in a while, Work got insane, My fiancee had issues, So did my car and This is the first chance I've had.
So ill Give you an update on The pluminator. :-D
Last week I was driving through the city "Portland Maine". I ran into some construction. Well the workers had failed to put a cone in a 1ft deep, by 3foot wide pothole, which ate my front passenger tire as I passed.
It caused quite a bit of damage. Which follows.
Blown Tire
Bent rim.
Cracked axle
Fractured Strut
Shattered swaybar Link.
Soooo I decided to replace all those, also went with Moog swaybar links and bushings.
Then it got worse
I installed the Axle, strut and links in no time with no problems. However when I got to the Swaybar bushings. Everything went wrong.
I ended up snapping off 2 of the 14mm Bolt heads for the Bushing brackets . Which caused my swaybar to basically smack violently against the underside of my PT every time I hit so much as a small crack in the road.
Took her to the Dealer, they quoted me at $300 flat to drill out the bolts, then tap new holes and threads for new bolts.
I said Meh cant be too difficult. *I've tap and died many bolts before.
.....BOY WAS I WRONG. All the bolts i've taped before , have been on the top or side of things, This was on the under carriage and the bolts were facing down So even though It was only about an inch of bolt to drill, and an inch of frame to tap......With my car firmly on jackstands I only had 3 Inches of clearance between the back end of my Milwaulkee drill.....and the pavement meaning NO LEVERAGE .
Here are some photos of the 7.5 HOUR job.
First we have the broken bolt, They were the rear Bolts for the Swaybar mounting brackets. One had broken on each side of the car, so I had to do this whole thing twice.
Next shows the bracket and how it was hanging with my swaybar.
Here we have a nice hole drilled through the bolt using a Carbide drill bit *titanium burnt out before i got any metal threads to come out, This was at low speed with oil :/* And the carbide took 2 hours per bolt to drill out!
Now this is after I Spent a good 35 minutes muscling the bracket back into place *believe it or not......these things are IMPOSSIBLE to bend*
And lastly the finished product. 7.5 hours later , 2 hours of drilling, 2 hours of tapping , 2 hours of banging, bending and prying the brackets and 1 hour of bolt modification *the ones I got were the right size, but way too long, had to chop them 3-4 times, then grind down the ends so they would thread......*
I have fixed my dang $6 brackets! :-D
Note to the wise.....haha IF you dont have a lift.......DO NOT ATTEMPT THIS. It takes forever! and you get zero leverage whatsoever. haha Its now 1:19 am. I started the job at 5:30 Pm and i Just got home from my brothers house from doing it..I wish I had dropped the $300 haha.....But....now my car doesnt clunk anymore :-D
Old 24 May 2013, 01:42 am
UptownSport's Avatar
Default Re: I'm Back!. With photos of course :-D
OMFG! Feel your pain.
Where'd you get a carbide drill bit?!
I just took sway bar off the Neon. total, unneeded, option!
Old 24 May 2013, 07:50 am
Good to see you back . Good that you back to work. Remembered you had said you were off. I work from a floor jack. With stands. So I know the feeling all to well. I usually start by pb blasting bolt from all sides. Many times there are small holes to spray the backside with a straw. Then I take a big ballpin hammer and pound on the head of the bolt a few good whacks. Then Ill use an impact. running it in first and then backing it out. If still tight I'll run it in and out a little at a time till I work it all the way out. I figure you tried these thing before the broke, but for the sake of others reading I threw this out. The money well feel better in your pocket today after a few hours rest. Good you back running again.
Old 26 May 2013, 03:46 am
Plume; that sounds like 2 bad days. Some states pay for car damage if it is due to their negligence. Worth a phone call.
Factory bolts are tough and hardened on the outside. Using a small sharp drill first then going to a larger drill seems easier.
As far as Busted idea of giving it a few good whacks, it's a good thought, but it won't get the car fixed !
Old 27 May 2013, 08:34 pm
Yeah it definitely was a struggle. My brother had the bits laying around in his garage, used to work on 18wheelers so he had to drill Iron, steel, aluminium , sometimes titanium.
Hardest part by far was the leverage. I ended up sticking my crank jack under the drill and running her on med speed while slowly increasing the jack height. Was certainly not a fun fiasco. But now she rides nice and smooth haha
Old 27 May 2013, 09:07 pm
No, it only keeps you from breaking the bolts to begin with. If it ain't broke you don't have to fix it. The whacks shears the rust bond between the two and allows the bolt to be turn out instead of break and tap. Same principles used with impact wrenches.
Old 28 May 2013, 02:42 am
Busted; the comment I made was not automobile related! HeHe
Old 28 May 2013, 07:46 am
Oh, I get it now! LMBO.
Old 28 May 2013, 09:53 pm
Oh god!. there's way too many sharp parts under my car to be doing that! lmbo
Busted_PT likes this.
Old 29 May 2013, 09:54 am
2step's Avatar
My dad actually invented a lever/fulcrum deal that clamped on to a drill handle so you could press down with your weight instead of pushing up. This was back when he had a part time mororhome repair business in his early retirement.
rob342 likes this.
Hump back hatch back conversion... Metaltwister Exterior Accessories Forum 48 14 Sep 2011 11:00 pm
Took some new photos... CYCLONE_06 General PT Cruiser Discussions 14 28 Mar 2011 09:36 pm
Photos motorheadmonty PT Cruiser Convertible Forum 2 18 Sep 2010 10:38 am
HELP with photos ptgtjoe Testing 5 31 Jan 2004 02:40 pm
