Lowered Suspension
Old 24 May 2013, 08:24 pm
Qwintus's Avatar
Default Lowered Suspension
Hi Everyone,
I am interested in lowering my car 2 inches with lowered springs. I drive on some rough roads sometimes and do a little "drifting" and doughnuts in the dirt. Will I have much trouble with the lowered suspension? If so, is there an alternative that will keep the car from becoming damaged? Thanks!
08 Base Pt Cruiser 75,000 miles
MODS: Airaid Cone Filter
Old 24 May 2013, 08:47 pm
Default Re: Lowered Suspension
Unless you hit some really BAD ruts and bumps, lowering will only cause the front rubber valance to hit a couple times. Won't really hurt but in time you might want to replace it (not hard) after awhile.
I'm not really getting the part about "alternative" to lowering it? Either you lower it or keep it the way it is.
Old 25 May 2013, 08:18 am
cruisin03pt's Avatar
I think hes asking if theres a way to lower the car and not damage it. To answer your question, no. Unless you drive slow, you will scrape parts on the ground. Plus, your spring rate is cut in half so every bump will feel bad.
Old 25 May 2013, 09:22 pm
Chriscokid's Avatar
I recently changed springs,struts, and springs.2" lower in rear 1 1/2" in front. It still rides about like stock unless road is rough.they were progressive so even though they're lower they have same amount of spring. You can see the difference in the picture of mine and my wife's .
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Tags
lowering, off road, suspension
Lowered pt's davea300 Wheels, Tires, Suspension 25 27 Mar 2012 04:42 am
LOWERED or NOT Wolfman Wheels, Tires, Suspension 9 14 Apr 2011 11:08 am
Lowered PT's CREWZIN Wheels, Tires, Suspension 16 11 Mar 2008 11:19 pm
Lowered bigdogdad Exterior Accessories Forum 23 23 May 2004 07:27 am
Lowered my GT GTSteve Turbo Wheels/Suspension/Handling 8 23 Sep 2003 04:29 pm
