watts link
Old 31 May 2013, 08:14 pm
Default watts link
How long are they supposed to last? I bought my car with 62k on it with a bad one, replaced it right away and now at 90k the damn thing is started to rattle on me again. Is there a better one then the oem one from the stealership that might last longer?
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
Old 31 May 2013, 08:25 pm
Default Re: watts link
Maybe the tie rod that is on the rods is bad and you could replace that. Also the spare tire rack gets lose and rattles to. Just some other possibility's.
Old 31 May 2013, 08:27 pm
hmm didn't think of the tie rod.I will check that tomorrow. I removed the spare tire cage to diagnose the issue so that is not rattling and I can move the rods connected to the watts link with my hand so I can tell its going bad.
Busted_PT likes this.
Old 31 May 2013, 09:31 pm
To be clear I am assuming that you replaced the bell crank and not the watts link assembly right? If you replaced the assembly you would have replaced 10 parts.
Not surprising that it is showing indication of watts link wear. The engineering as well the finished manufactured parts "suck" for proper clearance. Most owners and shops only replace the bell crank alone instead of the hardware and bar ends?
Old 31 May 2013, 10:28 pm
yea I worded it wrong, I only replaced the bellcrank piece the last time. I guess this time around im gonna replace all the parts.
Old 31 May 2013, 10:39 pm
Ya I figured......if you do get around to it again don't forget the bell crank secureing bolt!
There is a great thread that someone gave pictures and all about the replacement of them. Maybe CREWZIN or someone can post the link fro reference here ?
Old 02 Jun 2013, 01:43 am
yea the entire assembly is def. getting replaced, driving around some beat up curvy roads today that backend was all over the place.
Old 02 Jun 2013, 11:14 am
That is exactly what I am doing to mine. only I am re engineering it to work as Chrysler dreamed it was suppose to..
Old 02 Jun 2013, 10:37 pm
how are you doing it? I would like to update mine as well then.
Old 03 Jun 2013, 11:53 am
These are ready and the custom bell crank is in the works.
watts link woes... mdskinner731 General PT Cruiser Discussions 1 23 Feb 2013 05:14 pm
New Watts Link and Rods My02RedRide Tech & Performance Forum 0 23 Feb 2013 02:50 pm
watts link terrylittlejohn Tech & Performance Forum 12 25 Jan 2011 07:00 pm
Watts link bolt ado63 Tech & Performance Forum 2 11 Oct 2010 04:36 pm
watts link part numbers visual1 General PT Cruiser Discussions 4 21 Aug 2009 02:12 pm
