Rear brakes suck :/
Like Tree11Likes
Old 24 Jun 2013, 10:43 am
Default Rear brakes suck :/
So I've replaced my drums, shoes, hardware and wheel cylinders in the rear. But my rear brakes STILL suck haha. Where am i going wrong and what am i missing?
Old 24 Jun 2013, 11:25 am
Default Re: Rear brakes suck :/
since you did all that, i assume you manually adjusted the adjusters..
curiously, what exactly to you expect them to do? skid like a kid on a bike?
Old 24 Jun 2013, 11:37 am
cruserdad1976's Avatar
did you try backing up so set them???? exactally what are they doing or NOT doing
Old 24 Jun 2013, 01:28 pm
randyincctx's Avatar
Wink Re: Rear brakes suck :/
Now when you say 'rear brakes' are you talking about the brakes when you STOP the car with the brake pedal,or the brakes when you pull the parking brake lever......If you mean the brakes when your trying to stop...They pretty much always SUCK;Unless you install a brake proportioning valve ,most of the braking power is going to the front discs(75-90%?).....And if your talking about the rear brakes for parking,they are self adjusting ;They will always self adjust if you drive in reverse & pull up quickly & firmly on the E-brake/parking brake handle ;I do that occassionally just for that purpose(because of normal wear on the pads)But,especially after doing my rear brakes....
Aka:~KILLER~
Old 24 Jun 2013, 04:38 pm
QUOTE=randyincctx;482016]if you drive in reverse & pull up quickly & firmly on the E-brake/parking brake handle[/COLOR] ;I do that occassionally just for that purpose(because of normal wear on the pads)But,especially after doing my rear brakes....[/QUOTE]
you use the e-brake? for that? i always stepped on the pedal....like 20x.
Old 24 Jun 2013, 04:54 pm
The best thing you can do is convert to rear disc brakes.
Not a hard conversion using simple garage tools and parts both new and used are readily available.
....................Unless you install a brake proportioning valve.....................
This is probably not the best solution for a PT Cruiser or any vehicle with any form of anti-lock braking system. Way to much to reply technically to this just IMO DON'T DO IT!
Old 24 Jun 2013, 05:30 pm
Cool Re: Rear brakes suck :/
......I thought PT Cruisers came with 4 wheel disc brakes????;I haven't checked mine yet???..(Been working on the interior)....But,eHow.com states: 'The PT Cruiser came equipped with four-wheel disc brakes making brake repair on this vehicle a quick and easy project that requires no special tools to complete.'
Aka:~KILLER~
Old 24 Jun 2013, 05:39 pm
I do that also...But,that only gets the hydraulic brakes to seat;Manual parking brakes have a ratcheting adjuster inside the drums,and when you replace the shoes you need to adjust them as I stated before.....BTW;I'm mainly talking about my vehicles in the past...I'm still a noob and learning the world of PT Cruisers.
Aka:~KILLER~
Old 24 Jun 2013, 10:24 pm
Hmmm you need to re-read what I said?
If your PT came with drum rear brakes, it is an easy few hour conversion to go disc's and no special tools are required. All the disc brake parts bolt right up to the common rear axle. The overall brake feel and performance difference will be only slight because the brake bias will not be to much different between shoes and pads. And the braking is primarily 70% front and 30% rear on both brake systems anyway.
A common mistake many do is to go with a larger rear rotor to increase brake area and only mess up the brake bias causing a weird feel and brake control with very little improvement for the effort.
BTW with the limited information about your PT I read on your first welcome thread I believe you will find drums and shoes on your rear?
Now that is just a guess!!
I would guess that the OP simply need to check on what is on there and perhaps a fluid flush and change along with some better brake lines and that will be enough improvement for the brake system for what it is?
Old 24 Jun 2013, 10:46 pm
well I think the turbos may all have 4 wheel disk but my 06 touring is drum I know this cause I just changed them
Rear Brakes 03 PT HELP HELP HELP rahl Wheels, Tires, Suspension 5 09 Jan 2011 08:56 pm
Rear Brakes Wienerdog General PT Cruiser Discussions 5 10 May 2009 08:31 pm
Rear Brakes wazzzzman Tech & Performance Forum 7 09 Oct 2008 04:42 pm
rear brakes robin Wheels, Tires, Suspension 2 19 Mar 2007 09:13 am
rear brakes robin General PT Cruiser Discussions 2 19 Mar 2007 09:01 am
