TPMS system fault? looking for some how to guidance or projected cost
Old 30 Jun 2013, 06:25 pm
Default TPMS system fault? looking for some how to guidance or projected cost
Hello! First post, but ive been lurking for a month or so. I am fixing up my brother's 08 pt cruiser (I believe its the b series, NOT a turbo engine). He put a lot of wear on the cruiser due to travelling all across the state for training. I'd like to have it tuned up and runnint great when his deployment is up.
Back on topic, the tire sensor light will flash for about a minute, then stay on constantly. From the forum and other google searches, it seems this indicates a TPMS fault. The air pressure is at or above the requisite tire pressure. Ive disconnected the battery for at least 2 hours and the system has had a chance to reset.
I just moved near Concord, CA so I am worried about finding a trustworthy and wallet-friendly mechanic. Any ideas on the costs or tests involved in diagnosing this issue? Could I fix this system with enough diligence and the right tools?
Thanks for your time and assistance?
Old 30 Jun 2013, 07:17 pm
Ratdaddy's Avatar
Default Re: TPMS system fault? looking for some how to guidance or projected cost
Just stop by a good tire shop and have them check it out....Could be a faulty sensor or bad battery..
Old 31 Oct 2013, 11:53 am
I had a TPMS go bad in one of my front tires. My mechanic suggested that I replace it with the old fashion rubber valve stem. So the result is the idiot light flashing for about a minute every time I start the car. The TPMS runs approx 55-60 dollars. This is not required for inspection in mt state. (remember when we would have to look at the tires to see if they have enough air). Your brother my of had one go bad and replaced it with a rubber one. good luck
Old 31 Oct 2013, 11:55 am
Sorry, not mt state, But my state. also if you have the owners manual it explaines the flashing TPMS light.
Tags
errors, faults, tire pressure, tpms
TPMS availability Excedium Wheels, Tires, Suspension 2 18 Apr 2012 04:50 pm
TPMS?! echo Tech & Performance Forum 3 05 Oct 2011 10:38 am
Cooling system fault swanjack Tech & Performance Forum 12 16 Feb 2011 03:21 pm
need some guidance to change spark plugs in my GT turbo BrianW General Turbo Discussions 1 09 Jul 2010 12:38 am
Need Guidance DJ_Rit Turbo Performance 1 10 Apr 2007 11:52 am
