Wheel Alignment Specification
Old 08 Jul 2013, 03:17 pm
Default Wheel Alignment Specification
What are the recommended thresholds on castoer, camber, toe, thrust angles that could indicate wheel alignment issues? When should the shims in rear toe be replaced?
2001 - 2005 PT
Old 08 Jul 2013, 03:40 pm
Default Re: Wheel Alignment Specification
Might want to check out these threads on alignment.
Front Alignment
Wheel alignment SAI
Old 08 Jul 2013, 06:48 pm
Found it same tolerance for all PT models
| Repair Guides | Specifications & Troubleshooting | Specifications | AutoZone.com
Year Model Caster Camber Toe-in (in.)
Range (+/- Deg.) Preferred Settings (Deg.) Range (+/- Deg.) Preferred Settings (Deg.)
2006 PT Cruiser F +1.00 +2.45 +0.40 0.00 0.00 + 0.40
R +0.40 +0.20 +0.00 + 0.40
Wheel alignment SAI PeteyGT Turbo Wheels/Suspension/Handling 11 14 Apr 2013 10:05 am
Wheel Alignment Specs UnionJak Wheels, Tires, Suspension 0 16 Oct 2010 01:24 pm
Alignment necessary??? Shiniquiet Wheels, Tires, Suspension 5 28 Jul 2009 05:11 am
wheel alignment onyx pt Turbo Wheels/Suspension/Handling 2 19 Aug 2005 09:10 pm
