Need diagnosis help
Old 23 Jul 2013, 03:51 pm
Unhappy Need diagnosis help
I'm a retiree, so I have time, but limited expertise.
There is a knocking sound (sort of a thump, thump, thump....) that sounds like it is coming from the driver's side front wheel. As best as I can tell, the sound occurs at all speeds. It is very faint for the first mile to two, then gets louder. It seems to disappear when the car is not going straight, i.e., I don't hear it when I'm making a right or left hand turn or even in a curve in the road.
I've taken off the wheel but I can't see anything in particular that is wrong - can you Cruisers help?
Old 23 Jul 2013, 04:21 pm
Default Re: Need diagnosis help
First check the wheel lugs for tight. Sounds like a wheel bearing. Although primarily the make a grinding sound.
Old 26 Jul 2013, 04:14 pm
Thanks for the response. The lug nuts were very tight, I had to use a 30" cheater pipe on my wrench to loosen them. I fear it may be ball joints. I've changed the tie rods and lower trailing arms on a BMW 3 series, but the Cruiser is front=wheel drive and I fear it may be more difficult. Your thoughts?
Old 26 Jul 2013, 04:29 pm
Search on here and you tube. A crap load of PT stuff on you tube.
From what you've done I don't really think youd have an issue with the ball joints on a PT.
Welcome aboard.
Looking for help with radiator fan diagnosis dflarsen77 Tech & Performance Forum 4 19 Aug 2012 10:07 am
Timing belt diagnosis Cliffordpoe1 Tech & Performance Forum 11 21 Jan 2011 01:34 pm
Overheating diagnosis shammesfah Tech & Performance Forum 1 09 Sep 2010 09:32 pm
Overheating Diagnosis Gomanngo Tech & Performance Forum 4 17 Jul 2009 11:05 am
