Time For Tires need Help
Old 26 Jul 2013, 01:06 am
Thejman3's Avatar
Default Time For Tires need Help
hey guys,
i have a 03 pt gt turbo model with the factory gt wheels with the 205/50/17 tires, and i hate them, i hate small low profile rough riding tires. we dont have nice enough roads here for tires with no sidewall. i want some taller tires, what are some sizes to look at?
would a 245/50/17 give me any problems? these would give me about a inch or so more sidewall correct?
Mods/GTS Taillight covers/tinted backup lights/smoked license plate cover/Mopar blow off valve/8k hids/billet fuel door/Amber gold fogs/audio/video/blue pearl shift knob/All blue LEDs inside/Custom made hard pipe and air filter/Airhorn/black Billet upper grille/aluminum floormats/mopar boost gauge/mopar stage 1/Mopar aero kit (ground effects)/Black housing headlights/SRS 2.5' Catback/in channel vent visors/shaved badges/
Old 26 Jul 2013, 01:52 am
Lightbulb Re: Time For Tires need Help
Tire oh tire will you grant him this wish
Riding on this tire causes him much anguish.
Hate fills the heart of this young chap
Low sidewalls have proved to be nothing but crap
The roads are bumpy and rutted as hell
His patience is thin and his anger will swell
Old 26 Jul 2013, 06:00 am
Default Re: Time For Tires need Help
Don't know if a 245 will fir maybe a 225 but yes you can go in profile, it's gonna be a downgrade in transit response...but if you don't know what that means then it probably won't be an issue for you.
Old 26 Jul 2013, 09:51 am
2step's Avatar
A 245/50 will cause some problems. It will cause your speedo to be off (low) by about 3 or 4 MPH @ 60. It will take some of the pep out of your step like a final ratio gear change and add a bit more weight for the suspension to handle. But most of all, it probably would rub on the lower spring perch of the front strut. To test that out, slip your finger between the top inside corner of the stock tire and the bottom of the spring. If you don't have more than a 1/2" of space, the taller tire won't work.
You could mount the taller tires just in the back with no rubbing issues. That would get you half way more sidewall. But you would have to minus size the front wheels to 16" with a tire height same as stock to get more sidewall in front. The staggered sizes would give you a circumference difference front to back but not enough to cause the traction control to freak. That's actually not a bad look, though.
Old 26 Jul 2013, 12:01 pm
You probably would be better suited to the 16' wheels or even the 15"s with 205 55 16 or 195 65" 15"s This will have 0 affect on the speedo or the power. But depending on the tire and psi rating of the tire, wether the ride is soft. The lower the psi rating on the tire the better they will ride. Also you probably would be able to get some one to trade for your GT rims for there 16" or 15" if you wanted.
Old 26 Jul 2013, 12:29 pm
Yep what they say. But if you swapped to a 16's, a 205 50 will fit all the way around a 225 50 might fit in back but not the front.
Yes a taller sidewall will ride better (a relative term for me) but it won't respond to input as quickly...more sidewall...more flex.
Old 12 Aug 2013, 04:49 pm
Originally Posted by Thejman3 View Post
hey guys,
Try 225/45R17
If the roads are not that great the tire will be more wider, which will allow to have a better grip.
also you can change the rims and go
205/55R16 and it should help by making the tire taller, but then again I recommend the 225/45R17
Long time fan, first time owner skydog757 Welcome New PT Cruiser Members 10 19 Mar 2014 02:33 am
Do I need new tires...original tires (57,000 Miles) shelbyzman Wheels, Tires, Suspension 25 29 Mar 2013 12:09 am
New Tires, been running snow tires, bad me! DJmart Wheels, Tires, Suspension 9 13 May 2008 06:41 am
Time For New Tires bados Turbo Wheels/Suspension/Handling 1 11 Aug 2007 01:16 pm
Time for new tires - suggestions? Jason_L General Turbo Discussions 14 05 Apr 2006 12:44 pm
