how low can i go
  • 1 Post By Chromenut
Old 04 Sep 2013, 08:52 pm
Default how low can i go
What about 225/40 ...gives me 90 cm ...will that affect the speedo much
Because I think I will like the 'lowering' look without replacing the front springs
Old 04 Sep 2013, 08:55 pm
Default Re: how low can i go
Uhhhhh not a good idea
Old 04 Sep 2013, 08:58 pm
But y?
Old 04 Sep 2013, 09:17 pm
InfernoGT's Avatar
Originally Posted by hexarthra View Post
But y?
Because 90 cm is 35 in!
~25 in is stock. Any bigger and you'll be rubbing on the spring perch of the front shocks
2006 PTGT with 5spd. ~60k miles
Old 04 Sep 2013, 09:27 pm
Depends on your existing wheel and tire size whether or not it will affect your speedo.
I've got an '06 PT GT Vert, dropped on H&R SuperSport Springs, Tokico blues shocks/struts, then went with MB Drifterz wheels 18" x 7", factory wheels were 17" x 6.5", with 225/45 Pirelli P6's. I've spent quite a few days running at either 55 mph or 60 mph with three separate GPS units, each measuring my speed, and compared to my speedo I am going 3 mph faster than the speedo says. It's not exactly linear, but fairly close. As in at 20mph on the speedo, I'm only doing 21mph on GPS. At 85mph on the speedo, I'm doing 89mph on the GPS. Close to linear but not exact.
hexarthra likes this.
Old 04 Sep 2013, 09:28 pm
Got it...90 mm!...2 fifths of an inch
<img src=images/smilies/biggrin.gif border=0 alt= title=Big Grin class=inlineimg />Hexarthra...
Two automatic PTs,
06 touring turbo lite convert, 80k, Konig Incident wheels, Yokohama 225/45 R17 tires, K&N cold air intake, iridiun plugs
05 GT turbo HO convert, 40k, 03GT turbo wheels, Kumho 215/45 R17 tires, K&N cold air intake, Box Vision 9mm silicone racing wires, iridium plugs, drilled and slotted rotors w/ceramic pads, chrome rear tail light replacements
Old 04 Sep 2013, 09:30 pm
Good data Chromenut, thanks
Two automatic PTs,
Old 04 Sep 2013, 09:32 pm
90 mm I get, but your first comment is 90 cm!!! That's why I didn't make a remark as 90cm would be bizarre.
Old 04 Sep 2013, 09:40 pm
Thumbs up Re: how low can i go
Wow, math in public...sorry guys
Bottom line is that for 245/40, it will be 90 mm from the ground... the distance the sidewall will be to the tire bead...the height of the tire from the rim to the tread.
That will lower the profile of the car because it is stock at 102.5 mm
So using 245/40s would be 'lowering it by 12.5 mm, 1.25 cm, or about 1/2 inch...not so much I guess...but I like that there is more rubber on the road...so I'm there
Two automatic PTs,
