Creaking
  • 1 Post By melissa610
Old 09 Sep 2013, 12:30 pm
Default Creaking
Hi,
I'm not honestly sure if this belongs here or in another place, but here's my issue: When I stop or start, the bottom of the car creaks, like an old wood floor. I don't know if it's the brakes or the suspension, hence my confusion as to where this belongs. It's still under the Carmax 30 day warranty, so I will get it checked out, but I'd like to have an idea what I'm talking about before I go in. Any responses would be greatly appreciated!
Melissa
Old 09 Sep 2013, 12:38 pm
Default Re: Creaking
Push down in your bumper front or back. Get it moving , bouncing up and down to see if you can create the noise.
Old 09 Sep 2013, 12:50 pm
Good point. I'll try that. If it doesn't make the noise, I'll have them check the brakes. I will say that the noise does not occur when I'm driving. I don't think it happens going over bumps, either, but I can't say that I've specifically listened for it. I'll do that on the way home tonight. Thanks!
Old 09 Sep 2013, 04:14 pm
InfernoGT's Avatar
I had a creaking from my lower motor mount (torque strut) when I installed inserts that stiffen them. Just a little lube and it fixed it. Sounded like the noise you described, anyway. Well, to determine if the noise is coming from your motor flexing, step on the brake (assuming you have an auto) and slightly push on the gas. If you hear the creak its possible that you have a torque strut issue.
2006 PTGT with 5spd. ~60k miles
Old 09 Sep 2013, 04:22 pm
I'll check that out, thanks!
Old 10 Sep 2013, 01:45 pm
SO, I checked on the drive home last night, and it doesn't creak when I go over bumps. In fact, it only seems to happen at slow speeds, when I brake and as I pull out from a stop. I also noticed that it gets more pronounced when there are more people in the car. I'm going to take it to my mechanic, since I looked at the Carmax "limited warranty" (emphasis on the "limited"!), and apparently it only kicks in if there is a breakdown. This is just annoying, not a breakdown. I'd rather have my guys, who I completely trust, do it anyway.
Thanks for all your advice!
Old 16 May 2016, 06:41 pm
Bump! I have this exact issue now, first it was early morning cold start squeaks when going over speed bump a little faster then would go away after warming up. I fixed that mostly by greasing everything with a grease nipple by the front wheels and spraying liquid wrench type lubricating spray on any bushing I could find. I no longer hear the loud squeak on a cold suspension. I'm starting to hear slight squeak on a hot suspension now.. I just don't understand. Also ... Now I get this creaking OP describes but offered no possible follow up solution. I didn't spray lubricant on my motor mounts and not sure if I should. I need to do the torque strut test brb
Old 16 May 2016, 07:08 pm
Mine actually turned out to be a support bar that had been installed upside down. I will never buy from CarMax again. My mechanic fixed it, and it's been fine. Do have a mechanic check the motor mounts, though. I just had one replaced , and my mechanic told me they are notorious for breaking on the Cruiser.
cloudhidd3n likes this.
Old 16 May 2016, 07:30 pm
Huh, upside down? Wow. Thank you so much for responding!!
Old 16 May 2016, 08:20 pm
rsrocket1's Avatar
I found that the creaking in my PT was from the sway bar bushings. While I was rotating it downward to get to the lower control arms, I heard the familiar creaking and said "That's the sound I was hearing first thing in the morning while driving".
knocking/creaking noise jmont2536 Tech & Performance Forum 2 23 Aug 2011 08:21 pm
Creaking Noise 05 Convertible mopar1cjh PT Cruiser Convertible Forum 6 17 Dec 2010 07:04 am
Creaking Gas Petal delrosen Tech & Performance Forum 1 13 Apr 2010 03:22 pm
Creaking noise when turning wheel kappa_kruiser Wheels, Tires, Suspension 3 22 Jul 2008 06:14 am
creaking noise cruiser33 General PT Cruiser Discussions 7 28 Jan 2006 01:11 am
