Energy Suspension Bushing - Lower Torque Mount - Is this correct?
  • 1 Post By greeley
Old 19 Sep 2013, 01:52 pm
greeley's Avatar
Exclamation Energy Suspension Bushing - Lower Torque Mount - Is this correct?
Quick question for those who've installed the Energy Suspension lower torque mount bushing inserts: I'm putting on a pair and they seem to uh, stick out a bit! Are they supposed to? I called ES and they said there is supposed to be some bushing sticking out.
In the stock mount, the Chrysler bushings sit almost flush with the edge of the arm and the metal inside makes full bearing contact with the block. The ES mounts go inside, filling the spaces, essentially making it a solid block of rubber. I dunno about this--doesn't look right (see pics.) You're not supposed to remove or trim the existing rubber inside the arm, and ES clearly made these inserts beefy, but won't this pull the metal inside toward the block when cranked down to spec?
The first pic is the outside of the arm, the second pic shows the inside of the arm--the part that goes against the block. I know it'll squish down, but....
Anyone dealt with this one? You may know more than ES on this one.
Outside mount:
Inside mount:
**edit**
Measured the difference -- it's about .45 of an inch, uncompressed and including the zip tie button -- seems like a lot, given that the metal inside is supposed to make full contact with the block:
I also double-checked the part number stamps to make sure I hadn't reversed the ES bushings. This is according to instructions--but it almost looks the outer bushing would make a better fit against the block... did they screw up the docs?
Mr Reee: 2002 plain jane, 212000 miles, 2.4ltr
Old 19 Sep 2013, 03:16 pm
randyincctx's Avatar
Question Re: Energy Suspension Bushing - Lower Torque Mount - Is this correct?
I haven't done this procedure myself(yet?),but I have seen several threads,and photos about it......And something does look off?
Aka:~KILLER~
Old 19 Sep 2013, 08:31 pm
rcktpwrd's Avatar
Default Re: Energy Suspension Bushing - Lower Torque Mount - Is this correct?
those are defiantly not in all the way.
when I did mine I had to trim a slight amount from the inserts for them to sit all the way in the mounts. the inserts should be flush
Joel
www.rcktpwrd.com
Old 20 Sep 2013, 04:39 pm
InfernoGT's Avatar
In the center of the mounts there is excess rubber from when they were molded. Trim it and it might fit better. Also use some polyurethane-safe lube to help them slide in.
2006 PTGT with 5spd. ~60k miles
Old 25 Sep 2013, 09:52 am
greeley's Avatar
Thanks for the replies. I finally went 'duh' and got under there to look at the block to see how the set-up mates and discovered that the bushing does, indeed, fit sung as is because the thread receiving end on the engine sticks out about .45 of a inch (I was imagining it was a near flush fit.)
In other words, the ES bushing *appears* to be designed to go right up against the block, in addition to filling the voids in the stock torque arm. Makes sense.
Now I'll climb under there and see if it's melted after driving it around like that.
BTW--got all the ES done on the front end control arms and sway bar, with new tie rods, ball joints, and bearings in the hubs (they were rusty.) The steering and ride is tighter than Jack Benny and a dime. Woo!
Full report to follow once I finish the rear.
rcktpwrd likes this.
energy suspension control arm bushing questions jamestown478 Tech & Performance Forum 5 04 Jul 2013 10:36 am
How Hard Is It To Replace Lower Motor Mount (Torque Rod)? myjeephatesme Tech & Performance Forum 16 02 Nov 2012 06:50 pm
Energy Suspension Transmission Mount...? wheelgarage Tech & Performance Forum 8 27 Sep 2012 11:05 pm
Bushing Kit from Energy Suspension chigger_ns Wheels, Tires, Suspension 9 19 Apr 2011 10:47 pm
Energy Suspension Bushings android Wheels, Tires, Suspension 2 09 Nov 2004 10:02 am
