more steering wheel shake...
Old 22 Sep 2013, 02:27 pm
j0e j0e is offline
Default more steering wheel shake...
I recently fixed the pass side tie rod end and got rid of the wheel shake.
Yesterday I hit a block of wood on the highway!
Bent the front drivers side wheel (just a steelie), so I moved that wheel to the back.
Now my steering wheel is shaking again and I feel a "thunk" in the fron end.
The shake and rattle seems to be worse when turning right and smooths a little when going left.
Obviously it's worse at higher speeds.
Think I need a tie rod on that side now?
Any other ideas?
Old 22 Sep 2013, 05:01 pm
Default Re: more steering wheel shake...
It wold be just a guess of what damage that block of wood did to the under carriage. You gotta get under there and take a look. That bent wheel, even though it's in the back could be transferring the shake and thunk to the front.
Old 22 Sep 2013, 10:18 pm
j0e j0e is offline
I jacked it up to check for loose tie rod end.
Seems tight top and bottom and very minimal movement side to side.
Maybe a bent tierod?
I think I gotta get it on a lift and look.
Old 23 Sep 2013, 07:41 am
There should be no minimal. But you probably have another issue as well.
Old 23 Sep 2013, 11:39 am
randyincctx's Avatar
Question Re: more steering wheel shake...
Do you think the block of wood may have bounced up,and hit your axle,or CV joint?
Aka:~KILLER~
Old 23 Sep 2013, 01:18 pm
j0e j0e is offline
I don't think the wood moved at all.
It was a solid 3"x3" block; felt like hitting a curb at 50
mph!
I think it may have messed up an already worn tierod.
Going to have my mechanic inspect it.
Wish me luck!
Old 25 Sep 2013, 10:09 am
greeley's Avatar
I'll second what Busted_PT said, having just overhauled my rotten front end suspension and steering--there should be *no* play. Makes a huge diff in the ride and handling. Probably saves your tires too.
Mr Reee: 2002 plain jane, 212000 miles, 2.4ltr
Old 14 Nov 2013, 11:45 am
j0e j0e is offline
Finally got around to fixing this.
Turns out it was the outer tierod end again.
Changed it, did an alignment and it's pretty good now.
The car still has a little vibration when I get into higher speeds.
That could be the wheels and tires though; I'll know soon...
I'll have new wheels and tires after the weekend.
Old 14 Nov 2013, 01:17 pm
Keep us posted!
Old 14 Nov 2013, 02:34 pm
Thumbs up Re: more steering wheel shake...
Exellent!
Aka:~KILLER~
New steering wheel ptgrotje Interior Accessories Forum 8 13 Oct 2013 09:38 am
Source of front end/steering wheel shake VOETOM General PT Cruiser Discussions 1 19 Sep 2011 10:41 pm
wheel skin steering wheel cover chintzgirl Interior Accessories Forum 0 23 Oct 2010 08:05 pm
steering wheel mod camillion Interior Accessories Forum 11 02 Oct 2008 10:54 pm
O NO! Steering Wheel Wobble and Shake after Snow? Ctown Wheels, Tires, Suspension 7 24 Jan 2005 11:20 pm
