Front End Shakes
  • 1 Post By rob342
Old 12 Oct 2013, 10:27 am
Default Front End Shakes
Howdy! I'm new to the forums and I have a question.
I have a 01 cruiser that makes a shaking sound, almost like the lugs are loose on the front wheels but they are not, when I do about 40,60, and 75-80mph (and yes 80mph is the speed limit here in Texas). I have my wheel turned to the left or right just a little to keep my car straight in a straight line and it makes a rattling sound and it almost shakes the whole car and I can feel it really bad through my hand on the steering wheel when going 60mph. When I make a decent turn into a corner doing those speeds it will stop making the noise and shaking the whole car. I took it to a mechanic and he drove it, and said I needed a front stabilizer bar and that would fix the problem. My tires are also in bad shape and planning on getting new ones pretty soon, but need the front end fix before I get them. I just wanted to know if anyone else has this problem, and could possibly confirm that it is indeed a front stabilizer bad I need.
Thanks!
Old 12 Oct 2013, 10:40 am
Default Re: Front End Shakes
get the tires first. tires are the most common for what you describe and you say you need them anyways. usually i recommend rotating the front and back and seeing if the noise moves, but if the tires are all old, it might not help.
my front end did that a little and it was a combination of a worn ball joint and a worn outer tie rod. you can jack up the front and yank up and down on the tierod to see if there is any play in it. for the balljoint it is hard to verify it has play in it unless you unbolt the 2 strut bolts from the steering knuckle. with those out you can lift the knuckle up and down. if there's play, it needs replacing.
UptownSport likes this.
Old 12 Oct 2013, 11:00 am
mine felt like a shaking feeling in the steering wheel with a slight repetitive knocking sound that could also be felt
Old 12 Oct 2013, 07:40 pm
randyincctx's Avatar
Exclamation Re: Front End Shakes
I could understand if the mechanic told you,you needed new bushings & end-links on your stabilizer bar....But,for him to tell you a new stabilizer bar would fix the problem!?(Maybe if you run around hitting curbs with your PT,like Chromenut!)...IMO;I personally wouldn't take a bicycle back to that mechanic!......I'm gonna agree with Rob on this one;I had the same problem with my Ford Ranger,and it turned out to be the tires.....You might be able to check them by jacking up each wheel,and spin it to check for ANY anomalies,or out-of-roundness.
Aka:~KILLER~
Old 13 Oct 2013, 10:17 pm
Thanks for your input guys! I will buy some new tires, more than likely some pirelli's, but if I still have problems after I buy the new tires I will let y'all know!
Old 05 Feb 2014, 11:12 pm
Your problem almost sounds like an alignment issue. You should always get an alignment after installing new tires. In fact, you can try rotating your tires to the back and see if the problem goes away. If it doesn't it's probably not the tires.
2008 PT Cruiser Touring 135,000 miles
Old 05 Feb 2014, 11:44 pm
soonercruiser's Avatar
Cool Re: Front End Shakes
THIS^^^^
If you know that your tires are bad, why wouldn't you start with new tires and an alignment first?
Then, go from there!
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
A/C shakes car badly moonshadow Welcome New PT Cruiser Members 11 02 Feb 2014 04:47 pm
A/C not working and car shakes... jcmnz24 General PT Cruiser Discussions 6 29 May 2013 08:14 pm
08 pt shakes/shimmys KronosGear General PT Cruiser Discussions 7 11 Aug 2011 06:46 am
Car Shakes in Reverse niel Tech & Performance Forum 6 22 Mar 2011 09:54 pm
My 2004 LE shakes at 45 MPH frances General PT Cruiser Discussions 3 04 May 2004 04:28 pm
