CV Axle, Transmission seal leaks
Like Tree6Likes
Old 01 Nov 2013, 05:32 pm
Default CV Axle, Transmission seal leaks
Hey everyone, I really hope someone can point me in the right direction regarding this issue. I've been researching for the last month and a half but can't find an answer to my unique it seems issue.
I had a boot tear on my passenger side about 1.5 months ago. So I did the logical thing and I replaced both CV axles using Duralasts from AutoZone. I did the driver side. Then I did the passenger side. After a couple of days of my wife driving the car (it's hers) I noticed that the subframe was wet with transmission fluid.
So the next weekend I pulled the CV out and replaced the transmission seal. Test drove it and it was still leaking. The next weekend I swapped out the axles. It still leaks. The following weekend I dropped the transmission pan because I'm pretty sure the fluid was never changed at 140k miles. So I changed the filter and replaced the fluid. That didn't help.
Next I went to Napa and bought a transmission seal. I replaced that seal and it's still leaking. I don't know what could be wrong. The axle is seated in the transmission, everything is hooked up right, I installed the splines into the transmission with the gap on the snap ring up. I just can't figure it out. Before I changed the CVs, the passenger side NEVER leaked. Once the car was warmed up one day I got it up on the ramps while it was running, and moved the axle in and out at the transmission and watched the transmission fluid seep out from the seal....
I went and bought a cv axle at the junk yard today. I measured the diameters on that end and they are identical to the Duralast, everything is the same.
Does anyone have a clue what the heck is going on with this passenger side axle????
Thanks in advance, I'm at my wits end.
*Edit, I don't think I added the car's info. 2002 A/T w/o ABS.
Old 02 Nov 2013, 01:54 pm
Default Re: CV Axle, Transmission seal leaks
is it possible it is leaking from between the housing and the seal(as opposed to seal and the axle)? i used a little anaerobic sealer on the case opening before i installed the seals into the trans and then i wiped a little grease on the rubber part of the seal before inserting the axle.
i'd say do it one last time like this, and be really careful guiding it in there.
Old 03 Nov 2013, 03:06 pm
It's 100% coming from the seal and the axle unfortunately =S
Old 10 Nov 2013, 04:58 pm
I may have found the solution to my leaking axle seal problem, will post up after it's been driven for a week.
Old 19 Nov 2013, 05:44 pm
I think I was able to solve my problem finally. It's been a week since I installed the sleeve and some 250+ miles commuting highway and some rough back roads. No leak as of tonight. I'm going to do a little write up below in the event that anyone else ends up in the situation I was in.
First off, I stumbled across an Output Shaft Repair Sleeve while looking around the parts for the car on Rock Auto. I figured I might as well give it a shot for $20.
More Information for NATIONAL 99157
The sleeve sitting on the edge of the output shaft diameter.
Output shaft diameter.
Output shaft diameter + redi-sleeve.
The sleeve on the shaft and ready to go back into the transmission.
1 week later, it looks like a little liquid on there, but nothing has dripped down all week. I'm sooooooo happy that this leak has finally been fixed!
After pulling the axle out 6 times I should be set with this car other than oil changes for a while.
Thanks for looking!
Old 20 Nov 2013, 04:41 am
1 stick; excellent pictures and write-up. Thanks for helping others. And, oooh so clean!
Old 20 Nov 2013, 09:20 am
Yes, I agree with pt06. But sad that the axles are undersized and need you to spend $20 per too fix.
Old 20 Nov 2013, 07:00 pm
Thanks! I'm hoping it does help someone that may end up in the same situation I was in. 2 months of hell lol trying to solve this issue.
I don't know that they were undersize because I bought an original and they had the same dimensions. Maybe the surface smoothness was worn out or there may have been grooves in the output shaft from the seal. I'd rather pay $20 to fix the axle for another 100k+ miles than to have to deal with leaking tranny fluid and checking it every couple of days. I didn't find much regarding this specific issue so I'm not sure what went wrong on this car. Just bad luck I suppose.
Old 11 Feb 2014, 03:19 am
Hello not a PT Cruiser guy but had to add to this thread for others. I have a 2006 Toyota Avalon that did this same trick to me. Bought new axles because my boots were leaking grease and wife would hear a "noise when she turned". Installed complete axles from Autozone of the same brand. Developed new leak from the CV shaft into transmission. Bought new $20 seal. Still leaked but slower. Looked at old seal and found nothing that stuck out and bit me on the nose. Pulled shaft inspected and used a caliper to help look for differences and found none. Decided to install old shaft to see if it would leak, it did not. The old shaft was much harder to replace the "C" clip whereas the new one was super easy. The pressed on carrier bearing might be not pushed on far enough. So off to Autozone for a refund for both shafts. The other "new" shaft has a hole in it from shipping. The re-used box came with two holes in it that my finger could pass through without touching the side and they were where the boots sat in the box. This was not good but still only 1.5 days not 2 months! The Avalon drips right on to the exhaust so you know very quickly it's leaking. I found out we have a local re-builder that will do MY shafts for even less than AZ. Now I will never buy another set of rebuilt shafts. The only good is I got this repair so "down" it's not even funny.
Old 30 Sep 2014, 12:09 pm
Location: Somewhere in Central New York. Home of snow, ice, salt, and other nice things lol.
Hey 1stick Im so glad you put this info up. I have gone through three seals and taken this stupid axle out 4 times and it keeps leaking. Saw your post and went and spent $35 so i can have the national 99157 now so I can get this done. Was about to replace the drive axle again. but im going to try this first and must say for the first time in a few weeks im hopeful for a proper repair. Thanks again and Ill post once done if it stops the leak. Keep on cruisin friends.
Front convertible top seal leaks sometimes?? Popdart PT Cruiser Convertible Forum 9 05 Oct 2013 05:25 pm
Transmission seal leak rcalzadilla Tech & Performance Forum 2 17 Mar 2013 02:12 pm
Automatic transmission leaks Printman General PT Cruiser Discussions 2 10 Nov 2012 02:54 pm
oil leaks fancy Tech & Performance Forum 5 29 Oct 2011 07:48 pm
no transmission fluid? no leaks... bagwell General PT Cruiser Discussions 3 01 Oct 2011 10:20 pm
