New Here, Have a tire fitment Question
Old 03 Nov 2013, 10:23 am
Default New Here, Have a tire fitment Question
Hello,
I recently bought a 2008 PT Touring with 16" wheels. This car was my fathers who past away. I helped him shop for and buy this car in 2009. The car is mint and has only 24,000 miles. My guess is it still has the factory tires on it. they are 205/55/16.
I have a set of winters that I had on my last car that was were used for 1 season. They are 215/60/16. Does anyone know if they will fit with no rubbing issues?
Thanks!
Old 03 Nov 2013, 10:59 am
Default Re: New Here, Have a tire fitment Question
They are going to a bit taller and a bit thinner but not that much where it would make a big difference as far as fitment. If in real doubt, take one wheel off and have a tire store fit the winter tires and try it out.
Old 04 Nov 2013, 11:12 pm
Thanks, may give that a try.
2008 PT Cruiser Touring - Completely Stock
Old 05 Nov 2013, 10:45 am
2step's Avatar
No no. They are indeed taller but are also wider. But the problem is they are probably too tall and will rub on the spring perch on the front struts. To get a rough idea simply stick your finger between the top, inside of the present stock tires and the bottom of the strut perch to see how much space is there for a taller tire. My guess is there will only be maybe a 1/4" of clearance. (Because manufacturers round out their sizes sometimes tires can measure out smaller or bigger than the size they are claimed to be so you may luck out.)
For what it's worth, the bigger tires will work on the rear axle but with FWD you really need the "winter tires" in front.
Old 05 Nov 2013, 11:04 am
GAD, what was I thinking? Thanks 2step for jumping in. They will be taller and WIDER. Must have been daydreaming when I came up with my answer.
But it still wouldn't hurt to try one of the tires on the front before completely giving up on them. They aren't that far off.
Old 05 Nov 2013, 12:18 pm
cruserdad1976's Avatar
and remember the distance between the tire and the shock tower does not change it is a solid mount
Old 05 Nov 2013, 12:37 pm
VanillaVert's Avatar
This link helps a ton!
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
05 PT GT Vert, Airbox mod, K&N filter, NeedsWings intake pipe, Mopar BOV, MSD wires, Autotecnica Chrome Spears, APC Taillights, Mopar Stage One, UltraGauge, Energy front suspension kit, Moog spherical bushings
wheel/tire fitment question... j0e Wheels, Tires, Suspension 4 31 May 2013 08:30 pm
Tire question. pluminator Wheels, Tires, Suspension 4 28 May 2013 09:50 pm
Tire Question bucksfan1976 Wheels, Tires, Suspension 1 28 Jul 2011 11:11 pm
Tire Question thetunesguy General PT Cruiser Discussions 9 17 Feb 2011 04:08 pm
GT Tire question don668 Turbo Wheels/Suspension/Handling 7 14 Apr 2003 05:53 am
