How to tell when a CV joint is bad??
Old 21 Nov 2013, 12:24 pm
Send a message via AIM to BillsCruiser
Default How to tell when a CV joint is bad??
How can I tell if an axle CV joint is going bad?
I've got a lower speed, while accelerating from a stop light, chatter/mild vibration somewhere in the drive train that I can't locate. I feel it slightly in the seat and at the gas pedal.
It continues thru 1st, 2nd, and 3rd gear shifts (automatic) until I reach above 35 mph or so.
It does not vibrate at highway speeds. Both boots are OK and no noticeable clicking noises at full lock turns.
I do have front end squeaking noises while going over speed bumps. Assuming it's LCA bushings...
Could this be the vibration source??
The '05 has 122K miles.
Old 21 Nov 2013, 07:33 pm
UptownSport's Avatar
Default Re: How to tell when a CV joint is bad??
Doesn't sound like it.
The engine torque arms?
Old 21 Nov 2013, 07:47 pm
Don't think so. I replaced both pass side upper and lower TQ struts a few months ago.
Old 21 Nov 2013, 07:55 pm
The chatter has me stumped? But rotate the wheels front to back so you can elimate wheels as a problem.
Old 23 Nov 2013, 05:23 pm
There are issues with torque converters that come up rarely here.
It's always best to eliminate known issues before looking into less likely items like torque converters- If LCA rear bushings are bad, replace bushings before looking further.
CV Joint?? 808 Wheels, Tires, Suspension 16 27 Mar 2015 04:12 pm
Bad CV joint? xxptjunkiexx Wheels, Tires, Suspension 5 09 May 2012 01:17 pm
CV Joint garner49 General PT Cruiser Discussions 3 20 Oct 2010 08:17 am
U joint job help demon666 Tech & Performance Forum 1 18 Jul 2009 06:53 am
Bad CV Joint or Boot? jmack General PT Cruiser Discussions 5 13 May 2005 11:40 am
