Steering Rack Oversteers - Need Advice
  • 1 Post By rob342
Old 13 Jan 2014, 12:10 pm
Handy_Cruiser's Avatar
Default Steering Rack Oversteers - Need Advice
When I was under my PT this weekend, I notice shiny rub marks inside both front wheel well. It appears both front tires are rubbing when turning both left and right. And my tires are standard 205/55/16 size.
At first this puzzled me. Usually cars oversteer left or right but not both and not on both front tires. But then I remembered that when I changed out the inner tie rods ends on my Sebring convertible, there were vinyl bushings/shims that went on the shaft behind the inner tie rod ends that limited how far the car could steer in either direction. And of course, my PT has "newish" inner tie rod ends installed by the previous owner. Could my shims have been left off during this earlier work?
I can find no description or image of this on the internet so I was planning to go to a salvage yard and yank a PT inner tire rod end to see if there is indeed supposed to be a vinyl shims behind it that limit how far the car steers. But then I thought that maybe some of my PT brothers and sisters might let me know if this is the case before I spend more quality time beneath another wrecked PT.
Your help and constructive input is appreciated.
Old 13 Jan 2014, 03:14 pm
Default Re: Steering Rack Oversteers - Need Advice
i have read on here that some years had tighter turning radius's than others
Turning radius data for various PT models
my car has 195/65 15's stock. no rubbing for me, and my car has the tightest turning radius of all years and models according to the link above. maybe the rack was replaced with a rack off a manual trans 01-02 pt. if that is the case, just enjoy the 3' tighter turning and don't worry about it. unless it's making your tires wear funny or it reeeealllly bothers you, i wouldn't give it much thought.
pluminator likes this.
Old 13 Jan 2014, 04:50 pm
I believe 195/65/15 is stock.....Me thinks your tires are too big :-D lol
Old 13 Jan 2014, 10:10 pm
No my friend. The 2001 Limited version came with 16 inch true Chrome wheels and 205/55/16 was the size of the factory tires.
Old 14 Jan 2014, 07:24 pm
rcktpwrd's Avatar
I have changed both inner and outer tie rods on my Cruiser and there were no shims/stops that went anywhere in there...
I would agree with the post above that maybe someone changed out the rack and used one for a manual trans car not the correct for your car auto trans rack. They have different amounts of throw, the manual trans takes up less space on the left side of the car so the front wheels can turn slightly more.
Joel
www.rcktpwrd.com
Old 14 Jan 2014, 08:21 pm
Thanks, Joel.
In that case, I may pull some of those "stops" off of a Sebring convertible and use them on my PT. The oversteer doesn't seem to be that bad. I believe a half or quarter inch stop on each side will do the job.
Or I can just remember not to cut the wheels too tight. Of course, one of the things I was really liking about my PT was that almost zero-turn radius I have now. Too bad it's not supposed to be that way.
steering rack q's mdskinner731 Tech & Performance Forum 3 16 Apr 2014 08:15 am
Steering rack... justinbowser Tech & Performance Forum 3 26 Apr 2012 03:34 pm
Power steering rack ? 1lowufo General PT Cruiser Discussions 3 12 Mar 2011 10:24 pm
ADVICE PLEASE!!!! SORTING OUT STEERING RACK bobhils Tech & Performance Forum 0 26 Oct 2010 10:32 am
steering rack replacement linda General PT Cruiser Discussions 6 11 Jan 2004 11:30 pm
