REAR SHOCK BUSHINGS
Old 20 Jan 2014, 11:15 am
kctobyjoe's Avatar
Default REAR SHOCK BUSHINGS
Since it would BEHOOVE me to get this BEFORE I buy the shocks. Does anyone have a size and or part number for say Energy Suspension on replacing the rear rubbers of shocks with polyurethane? I HOPE to get that KYB special that Amazon is advertising BEFORE the price goes up ;-)
kctobyjoe
Old 20 Jan 2014, 11:21 am
kctobyjoe's Avatar
Default Re: REAR SHOCK BUSHINGS
I found two possible part number s from energy Suspension but they only list possible CHRYSLER parts and two different dimensions. HELP *Please*
kctobyjoe
Old 20 Jan 2014, 11:24 am
I would recommend not to replace the eye bushings in the shocks. KYB has a lifetime warranty but if you remove their rubber bushings and replace then with polyurethane bushings it will void the warranty. Also you will gain nothing by using them alone on the PT Cruisers rear suspension without other part upgrades and modifications. You may even get unwanted noises that will drive you "bonkers"?
To answer your question off the top of my head....IDK what the eye bushing size is.
Old 20 Jan 2014, 11:40 am
What he said!
Old 20 Jan 2014, 12:02 pm
kctobyjoe's Avatar
[QUOTE=NitroPT;508002]I would recommend not to replace the eye bushings in the shocks. KYB has a lifetime warranty but if you remove their rubber bushings and replace then with polyurethane bushings it will void the warranty. Also you will gain nothing by using them alone on the PT Cruisers rear suspension without other part upgrades and modifications. You may even get unwanted noises that will drive you "bonkers"?
SOUND ADVICE; I did not know KYB had a REAL lifetime warranty
kctobyjoe
Old 20 Jan 2014, 12:14 pm
[QUOTE=kctobyjoe;508011]
kctobyjoe
As long as the cover is not dented or punctures, if the shock leaks oil or sags a KYB dealer will replace it. In most cases prof of original purchase is not always necessary.
It is really difficult to hurt a KYB shock anyway.
rear shock time jamestown478 Wheels, Tires, Suspension 19 04 Jan 2014 02:03 am
REAR sway bar bushings... greeley Wheels, Tires, Suspension 6 05 Oct 2013 10:04 pm
NEW KYB rear shocks comes with no bushings ? jroman32 Turbo Wheels/Suspension/Handling 3 12 May 2012 09:27 am
Rear sway bar bushings 22dodge General PT Cruiser Discussions 8 20 Mar 2011 05:36 pm
Any Recommendations for Rear Shock Absorbers? jeremysaal General PT Cruiser Discussions 4 02 Oct 2010 04:09 pm
