Sway bar bushings????
Like Tree2Likes
Old 22 Feb 2014, 07:24 pm
Default Sway bar bushings????
Good day!
I've had a clunking underneath the front end for awhile now; been too cold for me here in Wis for me to want to get underneath. I checked a bunch of stuff today when I changed the oil, and the only thing I can find that is "loose" seems to be the front sway bar - there is play within the bushings.
Could this be it? It's a pretty loud clunking I hear whenever I travel over bumps or potholes (and there's lots of those right now!!!).
Thanks.
Whitty
Old 22 Feb 2014, 07:26 pm
Default Re: Sway bar bushings????
I think you solved your "clunking" !
whitty1700 and Busted_PT like this.
Old 22 Feb 2014, 07:39 pm
What he said
Old 22 Feb 2014, 08:03 pm
Quick replies!!! Thanks.
So in looking for bushings, I see there are different size sway bars for the same model and model year.
How the heck do I sort that out?
Whitty
Old 22 Feb 2014, 08:18 pm
Thanks - I see there's multiple sway bar sizes for the bushings. How do I determine the size of the bar?
Whitty
Old 22 Feb 2014, 08:59 pm
You should look them up for your model PT. If you tell us what it is there are many of us can tell you what you should have. There are only 2 factory options for the front.
That I know of?
Old 23 Feb 2014, 07:00 am
randyincctx's Avatar
Lightbulb Re: Sway bar bushings????
If you have a caliper measure the sway bar itself,that'll leave no doubt,and check the new bushings to that measurement before purchasing......If doing the bushings,you should also do the end links at the same time;Be sure and use something like PB Blaster on ALL bolts & nuts(especially for Northern PT Cruiser=road salt=rust) or you can end up shearing them off,the end links can be cut off with a hacksaw/sawzall,if they give you trouble.
Aka:~KILLER~
Old 24 Feb 2014, 07:41 pm
Mine is a 2008 base model; non-turbo.
Old 24 Feb 2014, 07:42 pm
Thanks for that tip on the end links - I'll include that in the project. They've gotta come off anyway, right?
Old 25 Feb 2014, 02:45 pm
Wink Re: Sway bar bushings????
Yeppers,and if your 2008 is a Northern car,exposed to road salt,they still be could be pretty rusty/sticky.....Even if there're not,cutting them off with a hacksaw (or even better 'Sawz-all') only takes a few seconds,versus struggling with the nuts/bolts.
You'll see what I mean,when you start to work on them....Just cut them in the middle,thru the old bushings and all,then remove the two halves easily.
Then replace with the new,and throw the old ones in the trash.
See also:
rusty anti-sway bar link bolt
Aka:~KILLER~
How do I install end link sway bar bushings? PlatyGrr Wheels, Tires, Suspension 3 06 Oct 2013 03:25 pm
REAR sway bar bushings... greeley Wheels, Tires, Suspension 6 05 Oct 2013 10:04 pm
Rear sway bar bushings 22dodge General PT Cruiser Discussions 8 20 Mar 2011 05:36 pm
front sway bar bushings soyomb Wheels, Tires, Suspension 0 16 Feb 2011 01:22 pm
Bushings umaxman General PT Cruiser Discussions 5 07 Sep 2006 12:09 am
