How to lower a pt instructions needed!
Old 05 Apr 2014, 07:24 am
Default How to lower a pt instructions needed!
Does anyone have instructions on how to lower a pt cruiser ? I can't find anything on the forums.
Old 05 Apr 2014, 02:19 pm
Default Re: How to lower a pt instructions needed!
springs, coilovers or airbags.
Or you could just take off the tires and sit it on the ground, that would lower it too
Old 05 Apr 2014, 02:46 pm
I think he is looking for a little more detail. since you have done it. I figured you would give him a little bit more of a how to detailed what to do.
Old 05 Apr 2014, 03:06 pm
vipergts's Avatar
Lowering springs are the cheapest most effective way...Different brands have a different effect on the drop...Here is an example http://www.ebay.com/itm/Tein-01-06-C...904755&vxp=mtr ...1.5 inch lowering front...2.0 rear...The rears are a snap to change...Less than an hour...Unhook bottom shock bolts and yank em' out...The fronts however are more involved...The strut assemblies have to come out and you need a spring compressor to change them...Might as well replace the top strut bearings while it's apart...Of course you will need an alignment after all of this...The camber will just stay in spec with a 1.5 drop...A reputable repair shop will charge around 150~200 to do the fronts
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 05 Apr 2014, 03:11 pm
vipergts's Avatar
Exhibit A 1.5 drop front...2.0 drop rear...
Old 05 Apr 2014, 06:16 pm
I agree with ViperGTS - I did the 1.5 front, 2" rear using H&R custom springs, made in Germany, powder-coated in silver to match my PT. Along with that, Tokico blue's for shocks and struts, plus shaved down my body bumpers so that I wouldn't hit on them too hard.
Now over time, those levels have lowered another half inch - front now is around 2.25" lower and rear is around 2.5" lowered, and with the Tokico shocks and struts, riding is very comfortable.
Sadly, you can't get the custom H&R's anymore, they only sell their regular ones here in the states, thankfully when I ordered mine from their factory I got them well made, 2mm thicker than the US ones, but they were $255 and you can buy the US one's for half that price.
Front:
Rear:
Old 05 Apr 2014, 07:06 pm
Post some recent pics to show how much it's lowered now
Old 05 Apr 2014, 07:12 pm
http://www.ptcruiserlinks.com/forum/...nt-spings.html
Needed: Lower T-stat housing & upper air box cover fabreezai Classifieds: Want To Buy 4 10 May 2012 02:47 am
Mopar BOV Instructions DTs_PTGT Stage Turbo Kits 24 12 Apr 2009 08:20 pm
Need instructions... turbomangt Exterior Accessories Forum 2 27 Apr 2004 06:42 am
Stage I Instructions DTs_PTGT Stage Turbo Kits 10 07 Aug 2003 09:09 am
Who wants to host S1 instructions? PVO PT General Turbo Discussions 7 28 Jul 2003 09:15 am
