They are pressed it. I haven't done it, but i'm told get a punch and knock old one out, then put new in and use nuts to "pull" it in.
Call a tire place - may be worth it to have them do it.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
Agree with QSD. If it JUST happened, call the place that did the inspection and tell them what happened. You can drive with 4 bolts, no problem.
As long as there is access from the rear to insert the lug in the hole. I have seen some vehicles where the hub had to be pulled to get enough room.
Take your receipt,and your 'evidence' back to the shop/mechanic who put it on,because it's 100% his/their fault.....Like you said,he crossthreaded it & probably over-torqued it too!
I gaurantee it took more the 100ft/lbs(MFG torque spec.s) to tighten a cross-threaded lug nut. ![]() ![]()
![]() Aka:~KILLER~ ![]() |
Its not hard if you find the notch:
Breaking wheel studs when changing a tire is incredibly frustrating. It can make your vehicle unsafe, as there are less lug nuts holding the wheel in place. Fixing the problem is very easy, and very cheap. With about an hour of time, you can change the wheel stud an be on your way. In order to change the wheel stud, you will need: A new lug nut A new wheel stud A hammer A breaker bar 3 trigs Socket set Disc brake spreader Scrap wood Jack String 1.) You will need to start by pulling the emergency brake and placing your trigs behind the three wheels that you aren't working on. 2.) Remove the lug nuts on the tire. They are 19mm. 3.) Jack up the car until you can easily slide the tire off, without rubbing the tire on the ground. 4.) Find the bolts that attach the caliper to the wheel assembly. There are two, and take an 18mm socket. You may need to use a breaker bar to get the bolts off, especially if they have never been removed before. 5.) Tie the caliper to a part of the car that will keep it out of the way. DO NOT LET THE CALIPER HANG BY THE BRAKE LINE. This could cause a break in the line, and would need to be repaired immediately for safety. 6.) Remove the rotor. If it has not been removed before, you may need to bang on it with the hammer to loosen it off the wheel hub. Make sure you place the scrap wood on the rotor in order to keep from damaging the rotor. 7.) Put the car in neutral so that you can rotate the wheel hub. 8.) Line the broken stub up with the notch that allows the studs to be removed. The notch is found on the back side of the hub, towards the front of the car. Place the car back in park. 9.) Using the hammer and the scrap wood, bang out the broken stud. Once it is loosened, it should be easy to pull out by hand. Take care to hit it as little as possible in order to keep from knocking the wheel bearings out of place. 10.) Insert the new stud as far as you can with your hand. This may take a little work, and you may need to flatten a side of the head in order to get it to fit into the notch. 11.) Put the rotor back on the wheel. 12.) Using a lug nut, finishing pulling the stud into the hole by tightening the lug onto the stud. Remove the lug nut. 13.) Reinstall the caliper. You may need to spread the discs in order to get it to fit around the rotor. 14.) Reinstall the tire. Tighten the lugs by hand. 15.) Lower the jack. Retighten the lugs by hand. 16.) Remove the trigs.
Original join date: SEP 2003 Steve/ Wayne NJ 2005 GT Vert / Black / 5 speed 2004 Dream Cruiser / 5 speed Traded for 12 Veloster 2003 GT / Blue / Auto /sold 2001 Touring/ Silver / 5 speed /sold on E Bay |
![]() Quote:
2008 PT Cruiser Touring 135,000 miles |
When I first picked up my cruiser, some of the studs were rusty and stretched. I didn't want to deal with them breaking down the road so I replaced all 20. Yes, that's right, ALL 20
2006 PTGT with 5spd. ~60k miles |
![]() Quote:
Thread Tools | |
Display Modes | |
What's this broken wheel/suspension thingy??? | konadave | Wheels, Tires, Suspension | 24 | 05 Aug 2013 06:53 pm |
Broken wheel stud | rkeene | General PT Cruiser Discussions | 9 | 30 Apr 2013 06:49 am |
Question apon part broken in wheel well | ptcruisn | Feedback and Support | 1 | 24 Jan 2013 03:56 am |
right front axil broken | stingers | General Turbo Discussions | 4 | 10 Sep 2007 05:27 pm |
