02 pt cruiser... Worst to happen driving with bad watts link ??
Like Tree4Likes
Old 18 Apr 2014, 02:23 am
Default 02 pt cruiser... Worst to happen driving with bad watts link ??
I have a bad watts link that needs to be replaced... This is my sole driving vehicle and it's now starting to shake anything over 80km/h.
I wanna know what will happen if I can't get it changed right away ?
Old 18 Apr 2014, 06:36 am
Default Re: 02 pt cruiser... Worst to happen driving with bad watts link ??
Explain what you mean by shake? What do you feel and how?
Old 18 Apr 2014, 07:19 am
Watts link or bell crank is known to cause clunking, but not vibration.
I think your vibration is due to another cause.
Start with putting front tires on back and see if anything changes.
mityqwik likes this.
Old 18 Apr 2014, 09:34 am
It is a clunking, it is the watts link.
It started off as only loud clunking when going over bumps, now it is still clunking but constant and makes not the steering wheel shake but my whole car. I just want to know what happeneds when it's not replaced right away as I can not change it right now
Old 18 Apr 2014, 09:57 am
cruserdad1976's Avatar
in a way you have answered your own question it just getts worse till it getts to the point where its as bad as it getts(you may be there now) clunking and bouncy ride
The read axel will not fall off or the tires will not stop turning its jsut the ride will be lousey and luoude
Old 18 Apr 2014, 05:45 pm
Sounds like bade shock to me.
Old 18 Apr 2014, 09:06 pm
While doing the watts link project I had taken the system completely off our PT. I drove without it for a week before re-installing it. I do not advise this but I drove around town and almost forgot that it was completely off the Cruiser.
I would have to ponder how a bad wattslink system could cause a vibration? Clunking and bad stability going over rail road tracks but a vibration....?
Not sure how a shock would cause a vibration either. You can run without those as well. Unless perhaps the piston was damaged and there was sticktion on the valve and body? But that would be real unusual for it to happen on a 2 wheel drive vehicle?
Old 18 Apr 2014, 09:34 pm
I don't doubt your watts link is bad, I am agreeing with Nitro that I don't think that is the cause of your vibration.
As I said, swap front tires to back, and see if the vibration changes.
Old 18 Apr 2014, 09:41 pm
randyincctx's Avatar
Lightbulb Re: 02 pt cruiser... Worst to happen driving with bad watts link ??
I agree totally....Your vibration sounds like #1-Bad Tire(broken belt/bulge).#2-Thrown a Wheel Weight(Tire Out of Balance),#3-Possible Bad Strut(front wheel hopping?)Moving the front tires to the back will determine if it is a tire,or something else.
Aka:~KILLER~
Old 04 May 2014, 09:55 am
Could also be a bad wheel bearing or both going bad, when I removed mine when I got the car to do a check over the inner race stayed on the axle while the hub pulled off, could a bad watts link not cause the wheels to be out of alignment tho causing vibration?
Silver Bullet - 2001 PT Cruiser Limited, 5-Speed, 2.4 N/A, No mods yet just fixing her up slowly
Watts Link or Watts Link Bushing? Judhudson Wheels, Tires, Suspension 17 06 Apr 2014 05:54 pm
watts link jamestown478 Wheels, Tires, Suspension 17 05 Jun 2013 03:14 pm
New Watts Link and Rods My02RedRide Tech & Performance Forum 0 23 Feb 2013 02:50 pm
watts link terrylittlejohn Tech & Performance Forum 12 25 Jan 2011 07:00 pm
Watts link bolt ado63 Tech & Performance Forum 2 11 Oct 2010 04:36 pm
