Retro style wheel rims
Old 17 May 2014, 03:10 am
whiteclaw's Avatar
Default Retro style wheel rims
Ok, so how does this work exactly. I see the retro style wheel rims, to give that classic look, however, I was also looking at those wheel plate things for the standard wheel rims where you insert them into the wheel rim and it protects the car from brake dust etc. However, people slated those stating they didn't allow enough air to the brake pads causing them to overheat and causing all sorts of damage to the wheel areas.
Those were called kleen wheels with a k
https://www.kleenwheels.com
So wouldn't you get the same issue with those retro look wheel rims?
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0
Old 17 May 2014, 06:43 am
Default Re: Retro style wheel rims
Probably doesn't help air flow...
My cure for brake dust was to replace the stock pads with ceramic pads.
Old 17 May 2014, 06:51 am
QSD is right but doesn't answer your question. I have someone in my old PT club that had the Kleen Wheels and never had a problem with overheating of the brake parts and as you've said, the retro wheels don't allow air to the brakes from the outside of the wheel and loads of people have gone with the retro style without a problem. I would think for "normal" driving, there's enough air from under the car to keep everything working just fine.
Old 17 May 2014, 11:17 am
harrym's Avatar
I have had chrome wheels on my 05 for several years with no problem of overheating. I never considered that they would restrict airflow.
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
Old 17 May 2014, 02:30 pm
whiteclaw's Avatar
I never considered about there not being enough air flow either. I was oroginally looking for a good way to keep these bad boys clean. Apparently they have been know to put a form of the kleen wheels on Ferraris so didn't understand this airflow and cooling issue
Old 17 May 2014, 02:56 pm
Originally Posted by whiteclaw View Post
I never considered about there not being enough air flow either. I was originally looking for a good way to keep these bad boys clean. Apparently they have been know to put a form of the kleen wheels on Ferraris so didn't understand this airflow and cooling issue
While I personally wouldn't use these on anything I own mainly because I like to show of my brake components let me "technee-a" little about the PT Cruiser front disc rotors and chillin.
Most of the air to radiate the heat of braking on the front is the fins of the rotor itself. Part of the ram air is picked up from you lower bumper openings. These 2 combinations perhaps contribute to 80% or more of the normal average daily driving disc rotor cooling.
You are not Road tracking your PT that I can see and unless you plan on doing a lot of high speed constant or continually braking in a fashion as that IMO I think you would be ok using these wheel inserts. I would really like anyone to demonstrate with some solid information even *personal use experience comments (*which we all know how I am about that) that this product would diminish overall normal usage braking capacity or cause brake component harm to a PT Cruisers front disc rotors brakes?
BTW how many have ever gotten brake dust down the side of any ride you have ever owned? Think about that for a moment!
Old 17 May 2014, 02:59 pm
It lessens but doesnt cure it
Old 17 May 2014, 05:05 pm
whiteclaw's Avatar
Honestly the muck on the wheels all the time, i assumed was mainly brake dust. Im all for cleaning the car, but if I am being honest, I can't do it every other day.
I looked at these sprays then saw those kleen wheel inserts, then wondered why not those lovely retro wheel rims instead, until I read this air cooling issue.
Just want the damn things to stay clean for little longer than a few days.
Old 17 May 2014, 05:52 pm
Then the easiest way is to follow QSD's advise and change to ceramic or any other brand of brake pads that advertise low or no brake dust. They go for a week or more at a time before needing cleaning provided you don't get other dirt/debris on them.
Old 17 May 2014, 07:01 pm
soonercruiser's Avatar
Cool Re: Retro style wheel rims
When I went to the ceramic pads on the 2006 na SoonerCruiser, frankly the brake dust was negligible, even after weeks!
Frank, aka SOONERCRUISER,
Retro rims Ameranth Wheels, Tires, Suspension 1 19 Jun 2013 05:15 pm
Retro style wheels for my '03 GT grungerockjeeper Wheels, Tires, Suspension 2 12 Mar 2010 01:25 pm
Looking to Buy (Old Style GT Rims 17x6) CruiserChris Classifieds: For Sale/Trade 1 18 Oct 2008 11:43 pm
Looking for Old Style GT Rims 17x6 CruiserChris Classifieds: Want To Buy 0 12 Oct 2008 11:15 am
Unique retro-rod style 2002 Limited Edition retro_rod Classifieds: For Sale/Trade 7 26 Jan 2008 10:33 am
