Front brakes pulsing(pumping)
Like Tree5Likes
Old 09 Jun 2014, 09:39 am
Default Front brakes pulsing(pumping)
Hello
2001 pt cruiser (no ABS)
Have a problem with my PT Cruiser
Braking at moderate to high speed the front brakes start pulsing.
I checked the pads (ok)and rotors (clean and shiny,no groves)
I read the forum and are still confused.(vacuum system leak, rotors warped
and so on)Then the issue with diogenal break system.
Anybody an idea where to start looking. I'm not an experienced mechanic.
Thanks for your input.
Old 09 Jun 2014, 09:45 am
cruserdad1976's Avatar
Default Re: Front brakes pulsing(pumping)
id change the rotors they are pretty cheap and that will eliminate a bigger right at the start--you didnt say how many miles on car or how many miles on breaks but still id do a break job and see what happens
Old 09 Jun 2014, 10:17 am
Agree.
Get new rotors and don't buy cheap ones.
Pulsing pedal is nearly always warped disks, and you will not be able to see the warpage.
Old 09 Jun 2014, 11:22 am
one more thing changing them on the pt is pretty easy as long as you have a few tools and the want to id say for 2 rotors and a set of good pads is still under $100 or really close to it
Old 09 Jun 2014, 11:28 am
One thing - the calipers require an 18mm wrench - most sets have 17mm & 19mm, so be sure you have an 18mm socket or box wrench before you start.
Old 09 Jun 2014, 01:47 pm
Thank you both.
What is the story about not pushing the caliper pistons back (to get the old rotor out and the new in) without opening the bleeder valve on the caliper. I read it will cause damage ?????
Thank you again !!
Old 09 Jun 2014, 04:18 pm
when i do my breaks ,i dont mess with opening anything i use a C clamp and the old break pad to compress the piston ,have for years on all the diffrent cars we do breaks on never had a problem that i am aware of--on the ones with the double pistons it is a little harder but it all works the same for me
On my cars once they get to the 100,000 mark i usally change the caliper, rotors ,break lines, and pads, but that gettes expensive ,and it most likely not really necessary, i just do it beacuse im that way.
Old 09 Jun 2014, 06:15 pm
Yep, leave the bleeder alone. You will only get air in the line. Do as Big daddy says above. Check the rear brakes and be sure that they are adjusted up properly if drum. Or you can warp a new set of rotors in a short while.
Old 09 Jun 2014, 06:21 pm
Originally Posted by Bugworks View Post
Thank you both.
Thank you again !!
I regard that as a myth - when I heard you can't push the pistons "backwards" - well, what happens when you take your foot off the brake? The piston retracts - "backwards".
I am like Cruiserdad - I've done probably 50 disk brake jobs on mine, wife's, kid's friend's cars - with and without ABS, and push in piston with a C-clamp, open no bleeder screws (and thereby let no air in) and never had a problem.
Check brake fluid level in master cylinder, because it will go up when you push pistons in, and if the fluid overflows, it can remove paint/make a mess.
cruserdad1976 likes this.
Old 09 Jun 2014, 06:29 pm
Thank you all !!!
Sounds much better and takes some worries off.
Are the rear drumbrake adjusters accessable from the back of the drum and what tool do I need. ? (screwdriver or similar) Which way do I turn the adjusters?
Thanks for your help.
Brakes pulsing/loss pressure bobdenverfan General PT Cruiser Discussions 2 26 Dec 2013 06:13 pm
Brakes "pulsing" after front pad replace and rotor turning Samson Tech & Performance Forum 8 28 Dec 2011 05:11 pm
Changing Front Disc Brakes and Front Bumper? HackMATTr General PT Cruiser Discussions 12 14 Feb 2011 12:58 am
Front Brakes HOW TO question for 03 PT barric Wheels, Tires, Suspension 11 15 Jun 2009 03:47 pm
Replacing front brakes tm05cruiser General PT Cruiser Discussions 7 21 Apr 2008 10:24 pm
