2001 Brake Booster Trouble?
Old 10 Jun 2014, 12:30 pm
Default 2001 Brake Booster Trouble?
My wife's 2001 PT Limited has just under 80k and we've owned it since it had a mere 24k on the clock 11 years ago. The front had new rotors, calipers & pads last year and last month it got new rear brake shoes, hardware & wheel cylinders and it stops faster than it goes!
Recently when it is first driven each day it takes several light stops before it gets any boost! Once it does it is fine for the rest of the day, even if parked for a long period.
Is there a check valve on our PT's? or is this a sign of a failing brake booster? Also this is probably a coincidence but I just recently found that the PCV hose was collapsing so I replaced it with a standard PVC hose until the correct formed hose arrives as it was not available locally!
Her PT has been a great car and never even seen snow until last winter but it seems like once it hit 70k it's gone into crash & burn mode!
Old 10 Jun 2014, 02:28 pm
Default Re: 2001 Brake Booster Trouble?
Had to replace the booster on mine. Went fast and had a rock hard pedal and hardly brought the car to a stop. Another time before replacing the booster, the idle would go up and down time after time and the pedal again was rock hard. that time I traced all the vacuum lines coming from he booster and found one had split. See if yo can check all those vacuum lines especially when they reach a "T" junction. Check for good connections and no splits in the wires. Not easy to trace the lines but it can be done.
brake booster vacuum tube help dav38spl Tech & Performance Forum 3 26 Oct 2013 06:18 pm
Vacuum line on brake booster. neoplanman Tech & Performance Forum 1 09 Jun 2013 08:24 pm
Power Brake Booster neocrusier Tech & Performance Forum 0 03 Jan 2011 08:38 pm
Brake trouble tpres Tech & Performance Forum 2 06 Jun 2010 06:27 am
Seafoaming PT through brake booster vacuum line? DIYPTGUY Tech & Performance Forum 3 22 Sep 2009 09:04 pm
