Plus Sizing ?
Old 20 Jun 2014, 09:32 am
Default Plus Sizing ?
I'm looking to take up some wheel well gap, without going to a lowering spring. Or at least make the appearance better. I now have a 205/55R16, a plus 1 is 215/45R17. Can I still go to a 215/50R17 without a problem? Your thoughts would help me settle mine. Thanks
Old 20 Jun 2014, 10:25 am
2step's Avatar
Default Re: Plus Sizing ?
The "problems" will be livable but still real. You will have speedo error due to the larger circumference and to a lessor degree you are effectively changing the gear ratio with a slight loss of performance off the line. But your "overdrive" will be more overdriven than normal which may give you a few more drops of fuel per mile on the interstate. It's very likely that a taller circumference tire will rub on the front strut. You can simply bend down by the front tire and slip your finger between the top, inside shoulder of your present tire and the spring perch of the strut to see for yourself how little room there is for more tire (taller tire). You can go to a staggered set up with a slightly taller tire on the rear axle with no rubbing issues or effect on the Traction Control. The rear tends to have a bit more "gap" anyway so doing that might get you close to your goal.
Old 20 Jun 2014, 02:17 pm
Get it lowered, changing the tires won't help much at all
Old 20 Jun 2014, 03:37 pm
cruserdad1976's Avatar
well i never liked a lowered car probaly cause i live on a gravel driveway but its hard tt get a tire to fill the wheel well with out some issues
Old 20 Jun 2014, 05:16 pm
Tanks for the info. I did do some checking to see what issues I might have, and the speedo did come up. I'll have to check out the lack of room in the front.
tire rim sizing bhunt41 Wheels, Tires, Suspension 3 29 Dec 2010 01:49 pm
Explain tire sizing cruisergeo Turbo Wheels/Suspension/Handling 13 28 May 2003 07:40 pm
