Vibration
Old 23 Jun 2014, 03:17 pm
Default Vibration
Changed my LH CV axle... Now I have a Vibration at higher speeds... Any ideas
Old 23 Jun 2014, 03:25 pm
Default Re: Vibration
Swap tires front-to-back and see if vibration changes...
Old 23 Jun 2014, 04:15 pm
Brand new tires.... And it dident vibrate before the repair..
Old 23 Jun 2014, 04:51 pm
what MPH does it start at and does it get louder the faster you go?
do you feel it in the steering wheel, your butt, the gas pedal?
does it get louder when you swerve left or right?
is it better or worse when you hit the brakes?
is it better or worse coasting vs accelerating?
does the car pull at all, or feel rickety at a certain speed?
any noise with the vibration?
i'd GUESS wheelbearing. maybe they over/under tightened it when they changed the axle. or.. maybe it's a bad new axle to begin with.
it's still a good idea to do what he says and rotate the tires. it's the only free thing to try before you $pend$$$
Old 23 Jun 2014, 04:57 pm
Well, then either install was botched or CV joint is out of balance - you do it?
If you had it done, take it back.
Old 25 Jun 2014, 09:04 am
I had it done at the shop I work at. Vibration starts at 65mph... steering wheel starts shaking. No noise while vibration. Does get worse while accelerating .. brakes dont change it...
Vibration jimdavis Tech & Performance Forum 7 12 May 2014 09:25 pm
Vibration at 70 mph Brunoka Tech & Performance Forum 5 19 Jun 2012 07:36 am
vibration bompa45 General PT Cruiser Discussions 2 24 Jan 2012 01:32 pm
vibration ? 2004PTCruiser Tech & Performance Forum 16 05 Jul 2008 09:40 am
Vibration between 40 & 60 mph???? anyone had this? gtbright General Turbo Discussions 10 16 Jul 2005 03:06 pm
