Removing inner cv joint on driver side
Old 01 Jul 2014, 12:22 pm
abigbutt's Avatar
Question Removing inner cv joint on driver side
Hello PT Cruiser peeps,
I'm stuck on removing the inner cv joint on my 2002 PT Cruiser. I've searched and haven't found the answer I need. The axle is removed from the cv joint and all is clear to pull it.
I had found something on using a slide-hammer and fork to remove it but I have nowhere to get that fork behind the tripod end of joint. Now I'm stuck. There is a plate(mounted with six bolts) on the transmission, that surrounds the joint. Do I try to remove this to get the fork on?
Any or all help/suggestions would greatly be appreciated!
Thanks, Jim
Old 01 Jul 2014, 01:03 pm
abigbutt's Avatar
Default Re: Removing inner cv joint on driver side
Well I kept digging and found a thread posted by SkeeJr How do I remove the CV Axle? . He used a combo with visegrips a plate and slide-hammer(Thanks SkeeJr!). I was able to pull it out with visegrips alone. I didn't think about tranny fluid(as it made a big mess). That's ok!!! Now we can start to putting everything back together.
Thanks, Jim
Removing drivers side cargo area side panel Jtwheels2007 Interior Accessories Forum 2 26 Mar 2012 08:03 pm
Driver side CV Joint difficulty removing.... wheelgarage Tech & Performance Forum 5 05 Jan 2012 01:01 am
removing side molding? theone General PT Cruiser Discussions 5 17 Sep 2008 10:26 pm
Removing side glass kevinl1058 Exterior Accessories Forum 0 06 Oct 2005 09:39 pm
Removing side SPEARS? 1lowufo Exterior Accessories Forum 17 05 Jul 2004 03:04 pm
