Raise the rear????
Like Tree5Likes
Old 26 Jul 2014, 02:19 pm
Default Raise the rear????
I am looking to raise the rear of my pt about 3inches... I added a cargo carrier to it for hunting trips and it drags the ground on bumps any held?
Old 26 Jul 2014, 04:10 pm
cruserdad1976's Avatar
Default Re: Raise the rear????
if the read drags what does the frount do????
Old 26 Jul 2014, 05:32 pm
Interesting project. You may be able to use Gabriel High Jackers?
If you are interested PM me only for this conversation.
rob342 likes this.
Old 06 Aug 2014, 11:37 am
last time i saw those i was in highschool and they were on an 81 camaro. my friend would fill them waaaaay up, i'd let the air out to be funny. convinced him they were leaking. -drove him crazy. about the 5th time i was letting the air out, he caught me in the act. LOL
Old 06 Aug 2014, 12:13 pm
i had them on my elcamino they worked pretty good
Old 06 Aug 2014, 12:19 pm
I looked and did nto see any for a PT what about longer springs???or shock extensions???and will it cause the tire to run on a angle if you get it to high
Old 06 Aug 2014, 12:33 pm
There are some good candidates that may fit they are just in the specification listing of a Gabriel catalog.
The twist beam axle was measured with drop bobs last year in a shop to see if the theory about the watts link caused a push to one side during its travel was correct. It wasn't!
Springs would work as well but like the shock their are no listing for OE replacements but a look in a specification catalog of TRW finds some interesting idea's.
This must be done by the individual doing the mods by themselves. I for one can only suggest where to look for parts to do this project. It requires some careful planning and consideration of the end results ,experience and knowledge of suspension systems and modifying them.
There was someone that started a thread a while ago asking about replacing the tube shocks on the rear with coil over shocks similar to motorcycle style shocks. This is also very doable but again it requires some planning to be successful and safe. There are also a line of coil over shock through MONROE and also some supplier for early VWs that may work? I had thought about doing this but got to far into my other rear end project to change.
Old 06 Aug 2014, 02:35 pm
Handy_Cruiser's Avatar
Adjustable air shocks or air bumpers would likely do the job.
Take a look at these that are designed to carry a heavy load at this link:
Air Lift PT Cruiser Suspension Kits | 4WheelOnline.com
Old 06 Aug 2014, 02:54 pm
These kits are designed to be used with factory suspension height. You would need to modify them to be used to raise the vehicle more than factory ride.
Not to say that it is not an alternative just a pricey one compared to other suggestions to make work.
I use to be a distributor for them and still have boxes full of parts,brackets,bags, air pumps, gauge,s lines etc for custom one off systems. Good company just not what the thread is asking for. Re: Raise the rear????
Old 06 Aug 2014, 03:16 pm
So does the OP really need to "raise" the back end of the PT or just be able to carry a heavier load at normal height? Cargo carriers usually just add additional weight.
Looking for side skirts and rear bumper cover or mopar body kit rear pieces jrbsr05pt Classifieds: Want To Buy 11 30 Sep 2013 09:14 pm
Rear Seat - Rear Window Switch Teenager feet protection oldorange Interior Accessories Forum 14 25 Sep 2012 02:36 pm
Can I use the front crossmember to raise the vehicle? iamgeek Tech & Performance Forum 5 18 May 2012 11:27 pm
Rear seat won't raise up RangerJ General PT Cruiser Discussions 5 18 Apr 2011 09:07 pm
Want to raise my GT a little SFsGT03 Turbo Wheels/Suspension/Handling 1 10 May 2004 01:42 am
