Seized Tie Rod end / Tierod end.
Old 31 Aug 2014, 06:53 pm
Default Seized Tie Rod end / Tierod end.
This Tie rod has givin me hell the last couple days. It was seized to the knuckle. a sledge hammer did not work. A tie rod separator did not work. I ended up jacking up the car on the bolt and then stood on the separator to get it to break free. The adjuster nut was also seized. I used the jack on a wrench to get it to brake free. Now the Tie Rod/ Tierod end itself is seized to the inner tie rod. There is no slot on either peice to get a wrench on them. I sprayed it with seize spray. The factory tie rod has a slot/crease that gives access to the threads. i sprayed the crap out of it. No luck. Can anyone help?
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=29148&dateline=131412  3683
2001 Touring Edition
Old 31 Aug 2014, 08:58 pm
Default Re: Seized Tie Rod end / Tierod end.
Inner tyrod requires special tool and heat, as in acyletene torch, will let you remove the outter tyrod.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 31 Aug 2014, 10:44 pm
Was able to get it off. Lots of Seize spray. Used a pipe wrench to grab a hold of the inner TR and used a TR Separator to turn the tie rod.
Old 01 Sep 2014, 01:49 am
Handy_Cruiser's Avatar
Yep. You definitely DO NOT want to reuse the inner tie rod if the outer was that bad. Better to just pull the inner and outer together as one unit and through them in the trash.
Both corrosive road salt and high heat, as from a bad wheel bearing or stuck brake caliper, can often cause this. You might want to inspect for both of the those. Glad you were able to get them loose.
RF Brake Seized Again 2001 Limited Sarasmiles Tech & Performance Forum 6 18 Mar 2013 09:43 pm
Seized Caliper - Common Problem? hppwdn Tech & Performance Forum 19 07 Jun 2012 09:32 pm
seized rim to rotor/hub crash2000 Turbo Wheels/Suspension/Handling 4 20 Nov 2004 11:10 pm
