Clicking from rear under heavy braking.
Old 20 Oct 2014, 07:33 pm
Angry Clicking from rear under heavy braking.
I'm new here so sorry if this is in the wrong place.
I have a 07 PT that has a loud clicking coming from the rear under heavy braking. I have put new drums, shoes and hard wear back there. I was thinking that maybe it's the hubs. I do know in the last year the gas mileage has gone down to now 10 mpg!!! The beaks are not hanging up and there is no Bering hum.
Old 20 Oct 2014, 07:37 pm
Default Re: Clicking from rear under heavy braking.
This car has 60,000 mi on it.
Old 20 Oct 2014, 07:46 pm
Is your engine light on? If so what are the engine trouble codes?
Did you adjust the brake drums after installing them?
Old 20 Oct 2014, 07:52 pm
You also might want to check your hubcap. If its loose it might be making the clicking sounds.
Old 21 Oct 2014, 03:55 am
No the light is not on and codes. The hub caps are sung.
Old 21 Oct 2014, 06:59 am
If you're getting 10mpg it sounds like you have a bigger issue than a clicking noise. I average 21 with a very heavy foot.
Did you already jack it up to try to shake, twist, and yank on things back there?
Old 21 Oct 2014, 08:24 am
I suggest you might have something like a vacuum leak in your brake booster or at the hoses going to the brake booster effecting your gas mileage and its making the leak detection pump in the back to start clicking or something might be making the leak detection pump to start clicking. With that low gas mileage I am surprised you are not getting the engine light.
Old 21 Oct 2014, 11:26 am
dalandon's Avatar
Sounds like what Im getting on mine but it only happens on tight left hand curves, no problems with hub bearings or cv joints. I agree check for vac leaks and it might be due for a tune up.
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 21 Oct 2014, 01:36 pm
There is no vac leak. This car is maintained to a T! Oil changed every 2,500 new spark plugs and wires, PVC, coolant flush, trans filter every year.
It has been to the dealer for this and they told me "we have no clue what's going on. Drive it. It runs and drives real good other then the noise"
Old 21 Oct 2014, 01:37 pm
The 10 mpg started when the noise started.
Heavy juddering when braking... Any ideas? Tobymelodeon Tech & Performance Forum 3 22 Aug 2014 05:23 pm
rear braking problem daft909punk General PT Cruiser Discussions 2 26 Dec 2013 10:52 pm
Rear brakes clicking Surf_Blu_Baby General PT Cruiser Discussions 6 02 Dec 2011 10:21 am
Rear popping noise when braking kbrockman Tech & Performance Forum 9 29 Jul 2007 04:08 pm
PT clicking in rear when stopping ptcruiser General PT Cruiser Discussions 3 14 May 2005 09:20 pm
