control arm bushings
Like Tree2Likes
Old 02 Nov 2014, 11:52 pm
edscrz's Avatar
Default control arm bushings
My mechanic showed me the bushings are out of the arms and need to be replaced quoted me $524 to replace bushings. Does the price seem right?
edscrz
Old 03 Nov 2014, 08:01 am
Default Re: control arm bushings
depends on what he is providing. But you would be better off buying your own and make sure your getting the new spherical bushing. Either by getting the bushing or whole arm.
Old 03 Nov 2014, 10:14 am
rckstein's Avatar
The bushings are relatively cheap and a lot of it is labor since the lower control arms have to be removed to replace the bushings. I saved some money on the labor by providing to my mechanic complete new MOOG control arms ready to install once he had the old ones removed. But their new style bushings weren't available at the time, but you can get them now, so that would be the ones to go with. The advantage of the new control arm assembly is that you also get new ball joints. Your shop price should also include a front alignment that will be required after the front end work is done.
OEM style:
New MOOG Spherical type:
myckee likes this.
Old 03 Nov 2014, 11:36 am
edscrz's Avatar
Where can I purchase the Moog control arms and what is the cost?
edscrz
Old 03 Nov 2014, 12:05 pm
rckstein's Avatar
There are lots of sources, I got mine off Amazon that had free shipping. Whatever your source, be sure that you have them verify that they do indeed have the NEW spherical bushing as there are still controls arms in the supply chain, under the same part number, that have the OLD style (OEM) type bushing.
Old 03 Nov 2014, 04:58 pm
SPLNeon's Avatar
How do the the new style Bushings compare to Prothane bushings?!
Old 03 Nov 2014, 05:07 pm
I didn't know they had made a better rear bushing. I already have new arms with the old bushing, but if they ever fail I will make sure to buy these new ones.
Old 03 Nov 2014, 06:36 pm
rckstein's Avatar
I can't answer that, I have no experience with Prothane products.
Old 03 Nov 2014, 06:58 pm
The OEM rubber bushing are a hardness of between 65-75 durometer and Polyurethane for street application is around 75-80. You will get better ride control generally with a harder bushing either rubber or polyurethane. However it is much harder to find suppliers of OEM replacement rubber bushing with a choice of durometer hardness. like you can with polyurethane.
myckee I am not sure what you mean you have new control arms on the rear? The re-axle assembly is a complete unit with welded control arms and rubber bushed ends. Maybe you meant the watts link rods?
Old 03 Nov 2014, 08:11 pm
I think he means the rear bushing on the front control arm.
myckee likes this.
Control arm bushings cowboyinboxers Tech & Performance Forum 11 04 Mar 2014 03:27 pm
Control Arm Bushings jaspersnowstorm Turbo Wheels/Suspension/Handling 5 27 Sep 2010 10:00 am
control arm bushings? nhdriver Tech & Performance Forum 8 09 May 2009 04:33 pm
control arm bushings 4SPEED Turbo Wheels/Suspension/Handling 1 28 Apr 2007 08:41 am
Control arm bushings Goldenturtle02 Wheels, Tires, Suspension 0 08 Sep 2004 08:40 pm
