New owner with replacement brakes questions
Like Tree7Likes
Old 05 Nov 2014, 03:16 pm
Question New owner with replacement brakes questions
I picked up an 05 cruiser with 65k miles and the brakes need to be replaced. There are a lot of choices on rockauto. With and without abs, rear drum or disc. Are the rotors different sizes depending on rear setup type. Mine has front disc/rear drum setup without ABS. Some listings say for 4 wheel disc and others don't. Are the rotors different sizes?
Old 05 Nov 2014, 04:42 pm
soonercruiser's Avatar
Cool Re: New owner with replacement brakes questions
How's about a few more vehicle details?....GT or na?
Am I missing something? If you have rear brake drums, you do not have any rotors in the rear....only the fronts like my 2006 base model had.
Upgrading to rear discs is another issue that there are experts here to tell you about.
Frank, aka SOONERCRUISER,
Old 05 Nov 2014, 04:48 pm
cruserdad1976's Avatar
Default Re: New owner with replacement brakes questions
rotors are the same except in the turbo and I think they are a little bigger( but it could be that its the calibers that are bigger not sure) just make sure that you get the set that is for YOUR PT------ mine is a 06 Non Turbo disk in frount drum in rear (just like yours) I put a set of slotted and drilled rotors in the frount with cermanic pads--like nitro will tell you most of the rotors are made in china but they do seem to be a pretty good quality
Old 05 Nov 2014, 06:03 pm
Not sure about GT or na. It says touring on the back. It is not a turbo model if that is what you meant by NA. It seems like it is the most basic version you can get. When I read the owners manual it had no optional features that I could see.
To be more specific Are the front rotor sizes the same between the 4 wheel disc and the disc/drum setups?
Old 05 Nov 2014, 06:10 pm
Yes. Only difference is that turbo rotors are thicker.
Front pads are the same size for any PT.
cruserdad1976 likes this.
Old 05 Nov 2014, 06:12 pm
boonie2's Avatar
JMO but id get ceramic pads
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 05 Nov 2014, 06:20 pm
id agree no break dust to clean off the wheels
Old 05 Nov 2014, 07:07 pm
OK. Thanks for the info. Fronts are same size pads and rotors except for turbo models.
I am getting ceramic pads and drilled/slotted rotors. Still looking around but it seems like I can get them for ~$100.
I am also doing the rear drums, shoes and hardware. It looks like I need the smaller size drums and shoes since I do not have ABS.
Old 05 Nov 2014, 07:24 pm
Roughly 80% of your braking is done in the front.
Old 05 Nov 2014, 07:37 pm
Yeah I know. The rear brakes are kind of loud to me. They look fine though. Going to replace everything anyway for piece of mind.
Some questions about rear disk brakes edb General PT Cruiser Discussions 15 23 Jan 2011 12:41 am
new pt gt owner with questions jacarc1 General Turbo Discussions 6 06 Apr 2010 10:41 am
New PT owner needs help with front brakes and maybe bearing replacement. Frankvs73 Wheels, Tires, Suspension 2 27 Oct 2009 07:15 pm
Turbo brakes - questions quicksilverdon General Turbo Discussions 4 01 Jun 2005 06:30 pm
New GT Owner...A few Questions jbrown1977 General Turbo Discussions 13 18 Mar 2004 05:56 pm
