Help Front thumping noise
  • 1 Post By Busted_PT
Old 18 Nov 2014, 05:13 pm
Default Help Front thumping noise
Hello. I have a 2003 pt cruiser gt turbo with 106k on it. I love the car but this noise is driving me crazy. ANY help will be greatly appreciated. It occurs at all speeds. It sounds like it's coming from both front wheels when they go over a bump or any change in road. It sounds like something is literally pounding on the floor pretty hard. It is like a thump on the floor. Steering wheel doesn't seem to be affected. I have been chasing this forever and here is what I replaced already. Balls joints (twice to make sure) lower control arms tie rod ends sway bar bushings(ends) every bearing on car both front and rear shocks struts. Lower motor mount And also had it aligned. I am totally stumped but I really want to fix this to have a quiet driver for the winter. Anyone's help would be great. Thanks.
Old 18 Nov 2014, 05:17 pm
Default Re: Help Front thumping noise
You've sure spent a lot on parts, and seem to have covered most common causes - have you had a mechanic look at it and test drive it???
Old 18 Nov 2014, 05:30 pm
I have taken it to my mechanic that does all my work on every car I have ever owned and never ever had a problem that he couldn't fix the first time. Then I took it to sears for the alignment and told them to fix it. They replaced the ball joints again and then gave up. Now I'm stuck with the car and tons of money into it and I just want it fixed.
Old 18 Nov 2014, 05:40 pm
LionPT's Avatar
Trans mount..??
Other than that...I would shake the exhaust from the header to the rear bumper.
Old 18 Nov 2014, 05:51 pm
I tried the exhaust thing already. But the reason I don't think it is any Trans or motor mounts is because I can go up a curb with the right wheel and hear the noise and then go up the curb with the left wheel only and hear it again. So it is something that is connecting both wheels I am thinking at least.
Old 18 Nov 2014, 05:59 pm
Do you have a strut bar installed under your hood? Sounds like it could be bouncing for some reason when the wheels move and hitting the hood. just an idea.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 18 Nov 2014, 07:23 pm
You didn't say you replaced the sway bar mounting bushings. Not the end links. But the ones that hold the bar up.
Wheel well thumping... MadMax38 Wheels, Tires, Suspension 2 30 Jun 2013 03:15 pm
Thumping noise/feeling on floor board?? jkriley Wheels, Tires, Suspension 9 27 Nov 2011 09:29 am
thumping sound pittguy Tech & Performance Forum 2 16 Dec 2010 09:47 pm
Hearing a thumping noise when turning in reverse Seawolf Wheels, Tires, Suspension 2 10 Oct 2010 12:40 pm
clutch thumping noise warpedhead General Turbo Discussions 2 23 Apr 2007 02:28 pm
