Angry growl from power steering
Like Tree2Likes
Old 25 Nov 2014, 09:44 am
Default Angry growl from power steering
Hi, my Cruiser has an angry growl and is noisy. The fluid in the resivoir is normal and during a belt/water pump job I replaced the pump - it is still as noisy as before. What am I missing here? The steering is unaffected by this as an FYI just irritatingly noisy
Old 25 Nov 2014, 10:23 am
Default Re: Angry growl from power steering
your kitty needs a steak
Old 25 Nov 2014, 10:58 am
I'm told there are two pumps. But given the fact nothing changed. If you flushed the fluid then your looking at a rack replacement. Short of someone with better knowledge giving you a better answer.
Old 25 Nov 2014, 11:00 am
A steak through the radiator perhaps ! I just found a thread on this and I'll post the link for those who stumble here first. Basically it boils down to a clogged screen in the reservoir and Chrysler wants us to use ATF+4 instead of power steering fluid. I will get a new reservoir and flush the system and report back on this, stay tuned... Power steering growl...the fix???
Old 25 Nov 2014, 11:25 am
A steak through the radiator perhaps ! I just found a thread on this and I'll post the link for those who stumble on this one first. Basically it boils down to a clogged screen in the reservoir and Chrysler wants use to use ATF+4 instead of power steering fluid. I will get a new reservoir and flush the system and report back on this, stay tuned...
You can back flush the screen in the reservoir. You will still have to remove to do it. Mine had power steering fluid in it from the factory(04) model. I put atf back in. Will be looking for the results of your fix.
Old 04 Dec 2014, 05:34 pm
Ok so lets get some Cruisers a good DIY on this issue as I cannot be the only one. First of all this reservoir is 91 bucks at the local Dodge place - not my idea of something to blow money on, so lets clean this out hands on.
I went to a you pull it and grabbed a reservoir cheap and decided to experiment. With a long drift sharpened I was able to remove the tangs that hold the lid onto the cup, there is a rubber seal between that. here is the view inside, as you can see this screen is extremely fine mesh and cakes up with muck.
[IMG][/IMG]
Old 04 Dec 2014, 05:42 pm
To get the filter out of the cup one must realize Chrysler preferred you buy a new one, I'm old school, I drilled out the three crimps with a 3/16 bit , I am going to rejoin it with special pop rivets later
I'm having trouble posting pics and maybe its because I'm a PT noob but stay with me...
[IMG][/IMG]
Old 04 Dec 2014, 05:50 pm
Did you try removing the gunk from the mesh with brake cleaner?
Old 04 Dec 2014, 05:53 pm
I made a puller to lift the filter up out of the cup, it worked great - too good actually because being untested I ened up putting the bolts right through the mesh screening.
At this point I am at a standstill till the weekend and will make some mods to the process and apply it to my cars own reservoir
Consider this a teaser and I'll do a better pictorial shortly - this is defiantly doable for us diy guys/gals
[IMG][/IMG]
Old 04 Dec 2014, 05:55 pm
yes and the brake cleaner seems to want to work but my can was about empty and I felt the filter needs to be accessed from underneath to be fruitful at this repair
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Help with angry thermostats? pluminator Tech & Performance Forum 9 13 Dec 2012 06:36 pm
Power steering growl...the fix??? Ironman Tech & Performance Forum 11 05 Feb 2012 07:42 pm
