TIRE PRESSERS
Like Tree6Likes
Old 19 Jan 2015, 05:10 pm
Default TIRE PRESSERS
So like the title says. What would you do in each case if you saw these two examples. Both are 205/55/16
Old 19 Jan 2015, 05:12 pm
LionPT's Avatar
Default Re: TIRE PRESSERS
Trick question...I've read the tire vs body label threads...lol
Old 19 Jan 2015, 05:24 pm
Not really. It was alleged that the one tire was not suitable for use on our car because it couldn't handle the load. In those threads. Here is a more compleat picture on that subject. Excuse the pun.
Old 19 Jan 2015, 05:57 pm
From Discount Tire:
"Where To Find Air Pressure Information
The correct air pressure may be found in the vehicle owner's manual or on the tire placard (attached to the vehicle door edge, doorpost, glove box door or fuel door). The placard tells you the maximum vehicle load, the cold tire pressures and the tire size recommended by the vehicle manufacturer. If you have trouble, visit your local Discount Tire location for assistance.
Another valuable resource is tire load/inflation tables. Your local Discount Tire should have a copy. Not only will this document tell you the correct tire pressure for stock sizes, but it will provide the information on optional plus sizes as well. A good example would be the findings on a Honda Civic with the stock size 185/65R-14. The recommended air pressure is 28 psi. Plus one size is 195/55R-15 with a recommended air pressure of 32 psi. Plus two size is 205/45R-16 with a recommended air pressure of 36 psi. Note how the air pressure increases with plus sizing to meet the load carrying capacity for the car."
Old 19 Jan 2015, 06:05 pm
cruserdad1976's Avatar
put 45 psi in them and drive on---ok so that is what my dad alwasy said
Old 19 Jan 2015, 06:11 pm
Also from Discount Tire about sidewall markings:
"Maximum Air Pressure - "300 kPa [44 psi]"
This indicates the maximum operating inflation pressure of the tire. It does not indicate the manufacturer's recommended inflation pressure, nor does it indicate the proper air pressure based on the vehicle the tire is mounted on."
Old 19 Jan 2015, 06:16 pm
Originally Posted by quicksilverdon View Post
From Discount Tire:
We are not talking hondas or anything but PT's here Note this is not placed in the non PT section. Here is the door info you just recommended. So you're saying put a cold pressure of 34psi in a max psi rated tire of 35psi?
Old 19 Jan 2015, 06:18 pm
Try to keep up - the Honda was AN EXAMPLE.
YES 34 PSI - like the sticker says.
So again your saying in the case of the Max psi 35 tire you disregard that info for the door sticker?
Old 19 Jan 2015, 06:19 pm
LionPT's Avatar
Well, I'd think you could use either one then, but the 44psi tire would be a harder ride...if inflated to 44.
Tire pressure. Door or tire? Cliff5550 General PT Cruiser Discussions 25 27 Apr 2013 04:29 pm
Need Tire Help bryan888 Wheels, Tires, Suspension 7 09 Mar 2009 03:06 am
tire fit...once more lol superpug666 Wheels, Tires, Suspension 0 07 Nov 2008 01:40 pm
What tire came on your GT? turbomangt Turbo Wheels/Suspension/Handling 15 22 Jan 2005 04:22 am
A little tire help PTGT Redman Wheels, Tires, Suspension 11 19 Feb 2004 01:41 pm
