Height of a original PT/GT
Like Tree6Likes
Old 16 Feb 2015, 02:36 pm
Mideskar's Avatar
Default Height of a original PT/GT
Hi.
Odd question perhaps, but does anyone have the information about the height of an original PT measured from the center of the wheel to the fender.
Both front and back.
Would like to see how much I lowered mine
Gone from lowered spring to coils, so I don't have any original measurement.
//Mattias
Old 16 Feb 2015, 02:43 pm
Default Re: Height of a original PT/GT
The measurements are in each specific model PT Cruiser factory service Manual.
There is no single measurements for all years and models.
Old 16 Feb 2015, 03:42 pm
Mideskar's Avatar
Okej, I mean give or take, if the car has certain miles on it it gets lower and lower as the springs worn out.
It not written in stone I just want an estimate, how high is an grandfather driven PT.
Old 16 Feb 2015, 04:16 pm
ok give but to be a bit more accurate and not very of the cuff with a responses we still need to know the model and year?
How about you post the four corner measurements that you have. Please adjust all the tire to the same air pressure and on level ground nothing extra in the car and no more then half tank of fuel. Close to half would be better easier to figure the pounds per gallon to compensate.
Some of might better help you with your thoughts about this?
Other wise you could have found it on googal search by now.
Old 16 Feb 2015, 04:30 pm
Other wise you could have found it on google search by now.
just to be clear...
the way i read his original post, he is looking for an odd measurement. from the center of the hub, to the highpoint of the wheel opening.
measured center of the wheel
to the fender.
like this:
i just can't reply, as i have no GT to measure from.
Old 16 Feb 2015, 04:43 pm
Mideskar's Avatar
Yeeea and there it goes from a simple question to science.
Or I can just wait until a PT comes by my workshop or go to the parking lot outside the mall. Btw. The year of my Gt is 2004.
I only hoped for an estimate Nitro.
Old 16 Feb 2015, 05:07 pm
rckstein's Avatar
Hi.
//Mattias
A while back I got this information from MOOG on original ride height of the PT, but they don't measure it how you want it measured, they measure from the ground to the wheel well opening at the top, or highest point.
Old 16 Feb 2015, 05:18 pm
It is not science and their is no such thing as an estimate to many variables.
Here you go an approximation.
With stock 17"wheel and factory 205/50/17 @ 28psi cold, ground to center of wheel well front 29 1/8 aprox.
rear 29 1/2 aprox.
Mideskar likes this.
Old 16 Feb 2015, 06:25 pm
Handy_Cruiser's Avatar
Hi.
//Mattias
Hi Mattias,
On my 2005 PT GT with what I believe to be original springs, the height from wheel center to fender is 15.5 inches for both the front and the back.
From just looking at the car, it appears the rear of the car sets higher. And this is also indicated by the slight angle of the bottom edge of the car's body. But the measurements to the fender are the same.
And it should be noted that my driveway has a slope to the rear. So my PT is not on completely flat ground. But I doubt the slope is enough to affect this measurement substantially. As discussed, this is an estimate.
Front driver side wheel
Back driver side wheel
Old 16 Feb 2015, 08:18 pm
Wow what a snow job!
Handy_Cruiser likes this.
Height from ground to seat? YorkieLdy General PT Cruiser Discussions 7 06 Mar 2012 09:30 pm
squish height murphy Tech & Performance Forum 2 07 Jan 2012 04:19 pm
Seat Height ? United Nathan General PT Cruiser Discussions 6 25 Jun 2004 07:17 pm
add seat height adjuster BLH1 Interior Accessories Forum 8 13 May 2004 10:02 am
Suspension height specifications... 03LtAldPTGT Turbo Wheels/Suspension/Handling 5 18 Oct 2003 03:31 am
