squeaking rear end
  • 1 Post By Handy_Cruiser
Old 19 Feb 2015, 02:24 pm
Default squeaking rear end
my 03 GT only has 95k miles on it (which is only 8.5k miles per year....not a lot of driving) and the rear has been squeaking and creaking for the last 2 years (in summer and winter) and is driving me nuts.
How many of you have had this problem? All the bushings look intact so I'm going to drill all the "u" shaped brackets install zerk fittings and squirt grease in.
Old 19 Feb 2015, 04:06 pm
Default Re: squeaking rear end
i have a lot of miles, but never a squeaky rear end. did you get in back and shake it? does it do it when you rock it side to side, or when you push up and down?
Old 19 Feb 2015, 04:42 pm
I don't think regular grease is good for rubber bushings...
Spray with silicone spray, then take a test drive to see if that is your cause or not.
Old 19 Feb 2015, 06:26 pm
Vlefaive's Avatar
The squeaking rear end up here in my part of the woods usually has me staying in the guest room.
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 20 Feb 2015, 06:17 am
Handy_Cruiser's Avatar
This squeaking is very common on 2001/2002 PT's with the rear sway bar. Has a rear sway bar been added to you 2003? And if so, try greasing the bar where it goes through the two rubber shackle bushings that hold it on the rear axle. See the silver part in the photo below.
Old 20 Feb 2015, 10:10 am
And mine came with grease - a whitish paste that I am quite sure was silicone-based, not petroleum based.
Old 20 Feb 2015, 01:55 pm
KA9VQF's Avatar
The bushing clamps on mine have grease zirks on them so they may be aftermarket. The anti sway bar looks to be larger diameter than the one pictured {and not nearly as clean}too.
I used lithium grease on all the zirks I could find {which were few and far between} under the car.
Don't put off until tomorrow what you might be able to put off indefinitely.
Ignorance can be cured with knowledge, but Stupid is forever.
2001 Limited rear squeaking sound mystery johngubbio General PT Cruiser Discussions 3 16 Sep 2012 03:02 pm
Wheel squeaking rookie878 Wheels, Tires, Suspension 2 20 Aug 2012 02:21 pm
Suspension squeaking 03PTMOM Tech & Performance Forum 15 29 Nov 2009 08:32 pm
Squeaking!!! Mr.Blonde General Turbo Discussions 12 25 Jun 2004 08:39 pm
Squeaking Front end Maldev Tech & Performance Forum 3 12 Aug 2002 12:45 pm
