Is this the control arm? Hearing a clunking sound
Old 01 Mar 2015, 08:41 pm
Default Is this the control arm? Hearing a clunking sound
Hi there,
Well first of all, thank you so much for your help.
I have a PT Cruiser 2004 with 140K miles, and I started hearing a clunking sound on the front passenger side after a 400 mile drive from Houston to Austin.
I took a picture of the part that could be making that sound (according to a friend of mine who knows about mechanics). I went through some similar posts and I believe this part is called the control arm and that I should get the Moog brand.
So I was wondering if this is the control arm indeed, and if I can just change the "joint" I show here or if I need to get the whole control arm (I am sorry, I don't know the exact name of the "joint"). Thank you so much!
Old 01 Mar 2015, 09:23 pm
rckstein's Avatar
Default Re: Is this the control arm? Hearing a clunking sound
Welcome to the forum.
That is the rear bushing in the lower control arm. You can get just the bushing and have a mechanic replace just that, if you can't do it yourself. But what I found out is that I was able to get complete new arm assemblies that come with new bushings and a new ball joint and I had my mechanic replace the complete arm assembly, cheaper than for him to work with the old arms and replace the bushing and ball joint. MOOG now has a new style "Problem Solver" bushing available. But if you go with new arm assemblies, you have to be sure to have your supplier actually check that the arms have the new style bushing. MOOG may still have a supply of arms in the supply chain that have their old style (OEM) bushing. They did not create new part numbers so there is no way of telling from the part numbers if it has the old or new style bushing. Good luck.
Old 01 Mar 2015, 09:38 pm
That is a strange looking thing. What is the shinny part at the top. Looks like the top of a bolt. If so you got a bigger issue than just a bushing. I'm on a phone so I can't inlarge with clarity. I will have my friend look at this in case I'm right. Could be unsafe.
Old 01 Mar 2015, 09:59 pm
rckstein's Avatar
To me it just looks like where the rubber part of the bushing has torn away and the shiny part is the bolt holding the arm.
Old 01 Mar 2015, 10:15 pm
Thank you for replying back!
That shinny part at the top is some grease that my friend put on the bushing, just to see if it would ease the clunking sound. I believe it did just for a few days and now it went back to it.
I read a post with a similar problem to mine, and the user got this part below for a 2001 PT Cruiser with 87K miles (mine is 2004 with 140K miles):
MOOG Part # K620010 Control Arm w/Ball Joint
Frt Susp; Lower; RH; Incl. bushings $79.79
More Information for MOOG CK620010
I will give it a try and report back if it was a match for my car. I am planning to fix it in the next two weeks.
One last question if you don't mind, should I also buy swaybar bushings and swaybar linkages? That same user bought these parts as well to fix his problem. Thank you so much again!
Old 04 Mar 2015, 12:28 am
Originally Posted by houstondriver View Post
Hi there,
That's the rear control arm bushing and yes, you can purchase just the bushing but it is easier to replace the whole control arm as an assembly since the bushings are pressed-in.
2008 PT Cruiser Touring 135,000 miles
Old 07 Mar 2015, 11:27 pm
Well thank you all for your help. Today I bought the failing part from Advance Auto Parts and took it to my mechanic. He charged me $85.00 for labor, while others were asking $120.00.
I don't hear the clunking sound anymore, except when making narrow left turns and then releasing the wheel. According to my mechanic, the parts are still "adjusting". I'm not that convinced with that explanation, but it's way better than before. I'll take it back if it gets worse, hoping it won't.
Thanks again!
This is the part by the way, "Driveworks Suspension Control Arm and Ball Joint Assembly"
Driveworks Suspension Control Arm and Ball Joint Assembly 520-328: Advance Auto Parts
Old 07 Mar 2015, 11:38 pm
rckstein's Avatar
Thanks again!
Did you do both sides? If one side failed, the other can't be far behind!
Old 08 Mar 2015, 11:06 am
I just replaced the passenger lower control arm for the time being. My budget is kind of low, so I figured I will just wait for the left one to go bad.
My mechanic checked the left one and said it was okay for the time being. (I read in other posts that the left one lasts longer than the right one, not sure if this is accurate or why.)
I also asked my mechanic if I should do an alignment and he said it wasn't necessary because the control arm is "fixed".
Thanks!!
Old 02 Apr 2015, 03:09 am
Well, I was at an angle laying on the floor so I would have to say a side to side movement. One side was worse than the other. When it clunks it is a deep metal clunk, normally at startup or shortly after. Goes away after a few turns and a little driving. After a long trip it will do it as well. There are grinding noises at startup as well as a screeching noise. I just put new brakes and rotors on the front last winter.
Tags
clunking, control arm
clunking sound Derren Tech & Performance Forum 8 01 Nov 2012 11:47 am
Would this be the source of my front end clunking? Control Arm Bushing (Pics inside) Capriman86 Wheels, Tires, Suspension 45 07 Nov 2011 06:15 pm
Won't be hearing much from me any longer careyk General PT Cruiser Discussions 13 01 Sep 2010 09:52 pm
clunking sound from front right end when turning any TSB mino General PT Cruiser Discussions 5 18 Oct 2007 03:04 pm
Clunking sound from rear left side Presario BJ General PT Cruiser Discussions 3 27 Apr 2003 06:50 pm
