Part number?
  • 1 Post By NitroPT
Old 21 Mar 2015, 02:50 pm
Mideskar's Avatar
Default Part number?
The PT doesn´t come with any dust/brake shields on it, only small heat shields to protect the lower ball joint (mine was non existing) and since the Chrysler dealerships here in my hometown are real dicks, does anyone have the part number of those shields (you put them on the ball joint before you insert it in the spindle).
Otherwise I have to go down to the dealership guys and try to explain it and it is a 50/50 that they come up with the right part (almost everything is custom ordered they never has anything on the shelf).
Old 21 Mar 2015, 05:02 pm
Default Re: Part number?
Hmm..well that would be for someone else who is good at researching parts. I looked at my Chrysler parts listing even with discontinued parts and it does not show them. I know I have them on my Cruiser??
In the Factory Service Manual there is a picture of it yet it is not mentioned in any way for the R&R of the ball joint.
You know aside from the other information I posted about the brake ducting, your BBK will runs much cooler in all operating aspects over the stock brake assembly.
This is all the parts fiche shows.
04656010AE BALL JOINT, BALL JOINT KIT. Lower Control Arm. . Less Seal Boot.
BALL JOINT. Lower Control Arm. Less Seal Boot. . ST. Required: 001 04656010AE
04656464AA SEAL. Ball Joint.
SEAL. Ball Joint. . ST. Required: 001 04656464AA
04694745 FITTING. Ball Joint. Zirc. . FITTING, Lube.
Mideskar likes this.
What is part number maddeath Exterior Accessories Forum 2 23 Feb 2013 02:37 am
Help with a part number? thesameguy Tech & Performance Forum 4 27 Nov 2012 08:13 pm
need a part number OurPTGT Turbo Performance 9 01 Sep 2012 08:21 am
PCM Part Number? sandy64 General PT Cruiser Discussions 3 27 Apr 2011 11:48 pm
Need a part number! skokz Tech & Performance Forum 1 17 Sep 2008 06:57 pm
