Wheel Bearing?
Old 09 Apr 2015, 12:41 pm
Default Wheel Bearing?
I am in need of some thoughts on this one... can't figure it out, my mechanic can't figure it out...
I posted some issues regarding my ABS/Traction issues a couple of weeks ago but still can't seem to get a resolve.
I sometimes feel vibration on the brake pedal and sometimes can hear a rubbing sound when driving slowly, particular when slowly curving (as in a park). Sometimes when making sharp turns or hard turns (merging from one highway to the next), I here a pop/crack/something sound. Its definitely coming from the front of the car, I think more on the driver's side. The car has new control arms, bushings, shocks, tie rods.... everything seems tight on the front end but I still hear the noise and have ABS issues. The ABS and Trac lights go on and off but report no codes. The sensors are all reporting the same wheel speed when tested.
One other odd piece of information: When the weather is cool, the issues are SIGNIFICANTLY reduced. Most times in that weather, the rubbing sound doesn't happen and the brakes never make the vibration/sound even though the lights may still come on.
Suggestions? Thoughts?
Need some thoughts on this one, the mechanic has not found anything that explains these issues yet.
Old 09 Apr 2015, 08:25 pm
Default Re: Wheel Bearing?
I have a similiar issue. I am thinking it is my cv joints
Tags
abs.brakes.traction, wheel bearing
Wheel Bearing's anyone? TrannyManny Wheels, Tires, Suspension 13 30 Oct 2011 10:14 am
Wheel bearing!!?? jrs61282 Wheels, Tires, Suspension 0 11 Jun 2011 12:46 pm
Wheel bearing issue? scrisp2 Wheels, Tires, Suspension 10 26 Dec 2009 04:13 pm
which wheel bearing musicmanchuck4 Wheels, Tires, Suspension 0 08 Apr 2009 06:48 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
