I replaced the lower control arm but still hear a noise - should I be concerned?
Old 14 Apr 2015, 11:11 am
Default I replaced the lower control arm but still hear a noise - should I be concerned?
Hi there!
Well first of all, thank you very much for your help.
I replaced the passenger lower control arm about a month ago with a new one from Advanced Auto Parts. The ride is way better than before and I don't hear a clunking sound anymore, except sometimes when I make a wide left turn or when I accelerate quickly.
To be honest, I wasn't expecting a perfect fix because I didn't use the OEM parts. That little noise doesn't really bother me as long as it's a safe ride.
But my question is - should I be concerned by this little noise? I'm afraid that it may get worse in the future and eventually make it an unsafe ride. I think my mechanic did a great job, I told him about the noise and he told me that the parts may take a while to "adjust" but I still hear the noise.
And a second question if you don't mind - I can feel the car pulling toward the right (the side of the new control arm) which it didn't do before. Is this normal after replacing a control arm? I'll need to get an alignment for sure.
Thank You!!
Old 14 Apr 2015, 12:18 pm
VNT's Avatar
VNT VNT is offline
Default Re: I replaced the lower control arm but still hear a noise - should I be concerned?
How many miles on the car?
You may need an alignment if the car is pulling to the right.
Make sure all the air pressure on your tires are correct, sometimes that can cause drifting if under inflated.
What condtion were your front sway bar cushions and the end links?
If worn they can cause noise.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 15 Apr 2015, 09:20 am
Hi!
I'll definitely take it for an alignment ASAP, thanks!
My car has 140K miles by the way.
Regarding the front sway bar cushions and end links' condition, I'm afraid I didn't ask my mechanic about these, but I suspect they were fine because otherwise he would have told me. But I will definitely ask him about these next time. Thank you!
Old 15 Apr 2015, 09:47 am
I would not assume that the sway bar cushion and end link bushing were looked at. If they were not mentioned they may not have been considered during the inspection by the "mechanic"?
Any noise that is not normal should be a concern to investigate their origin.
Tags
alignment, control arm
replaced upper and lower motor mount, still rough influenze Tech & Performance Forum 11 30 Oct 2014 11:35 pm
Need help after a turbo was replaced and it still makes the noise mrpilat General Turbo Discussions 5 22 Jun 2012 01:31 pm
Belt noise - but all belts just replaced... stek2008 Tech & Performance Forum 3 30 Jan 2012 09:09 pm
Replaced Lower control arms xwing777 Wheels, Tires, Suspension 3 30 Jan 2012 08:14 pm
Considering purchasing new Pt - But Concerned? emhg89 General PT Cruiser Discussions 9 04 Aug 2007 02:02 pm
